Frontera Key 2004-5 model
Frontera Key 2004-5 model by berksman1 on Fri Jan 16, 2015 12:10 am
Hi there just changing the outer casing on the key as rubbers are worn on the on off push button. on doing so the case that hold s the battery has come away and i guess will now not work correctly do to no longer been attached to touch circuit?
is there an easy fix or do i have to go say hello to vauxhall and buy new keys and then have them reset to car?
thanks in advance Chris
berksman1
Re: Frontera Key 2004-5 model by 4x4 bobby on Fri Jan 16, 2015 9:14 am
I had the same problem. Key blade was fine but battery holder had come adrift. I went to vx and it cost me £96 including programing the fob to the truck. Took him 10 minutes! People on here do know of a cheaper way but you need equipment to program it. :thumbup:
Re: Frontera Key 2004-5 model by DarrenH_2.2 on Fri Jan 16, 2015 2:59 pm
this also happened to one of mine, i had a bit more of a blue peter solution.
i used a no.10 scalpel and cut away a tiny amount of the plastic stand-off "leg" between the battery holder and the circuit board, thus revealing a bit more metal inside it, scrapped the chrome off the metal slightly then flux+soldered it back on to the circuit board.
DarrenH_2.2
Re: Frontera Key 2004-5 model by dave1966 on Sat Jan 17, 2015 3:15 am
Hi.
I had this with our key fob to our Frontera and I sent mine to someone one ebay and got ours repaired and when it came back,I did not have to re-program the key,if I remember correctly it cost us alot cheaper than Vauxhall because we do not have the "Vauxhall pass card".
I found this link on ebay:-
http://www.ebay.co.uk/itm/Vauxhall-Opel ... 259d9cc893
This is the link to the people that sorted out our key fob:-
http://www.ebay.co.uk/itm/Vauxhall-Astr ... 4cf43fd1d7
R.I.P Sable!(2005 to 2013)
dave1966
Re: Frontera Key 2004-5 model by unicorn_lion on Sat Jan 17, 2015 8:01 am
Try Martin Imber http://www.imber.me.uk/ He repairs key fobs- 12 quid- 17 if you want a new case
Greg
unicorn_lion
