Frontera Technical Support • View topic - Leaking A series Moon Roof
Leaking A series Moon Roof by jaybrian32 on Wed Dec 17, 2014 6:46 pm
how do can anyone tell me where the drain points are on an A series Swb moon roof, mne leaks when its been stood in ran all day, I've had the panel out, cleaned the inner and outer seal, no dice. I've noticed a small channel that runs around the roof opening approx 2mm wide, but can find where this would drain
jaybrian32
Registration Year: 1999/S
Vehicle Name: Oliver Reed
Torsion bars tweaked 0.75"
2" Body Lift
Custom roof mounted light bar
Cb installed in dash.
33 12.50 15 Bf Goodrich MT's
bluetooth stereo with USB.
JBL 6x9's in the rear
Fire Extinguisher
Re: Leaking A series Moon Roof by DarrenH_2.2 on Wed Dec 17, 2014 6:55 pm
edited as i missed the swb bit
DarrenH_2.2
Re: Leaking A series Moon Roof by gregster on Wed Dec 17, 2014 7:33 pm
If you look on the C posts there are two things that look like grills that are held in with a few torx screws...whip these out and I think the drains pass down through there...
Re: Leaking A series Moon Roof by jaybrian32 on Wed Dec 17, 2014 8:38 pm
Yeah those are easy to find behind the rear light clusters, its the actual points on the roof where it drains from I'm searching for, hazarding a guess they're blocked if I can't find them.
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by 4x4 bobby on Wed Dec 17, 2014 9:05 pm
Remove the moon roof and put an air line on on the pipes behind the grills in the c post that will blow the crap out!
Re: Leaking A series Moon Roof by jaybrian32 on Wed Dec 17, 2014 9:24 pm
Do they only drain on the rear then? Or are is there the same arrangement up front?
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by jellybaby on Thu Dec 18, 2014 12:21 am
Nope only drain to the rear as the roof can be removed. Check the clips actually pull the roof down tight I had to adjust mine been a while since I had my 2.0 though.
Re: Leaking A series Moon Roof by jaybrian32 on Thu Dec 18, 2014 7:51 am
Now that makes sense, didn't realise the clips were adjustable, do you remember how you adjusted them?
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by jellybaby on Thu Dec 18, 2014 6:33 pm
Think there were screws on them.
Re: Leaking A series Moon Roof by jaybrian32 on Thu Dec 18, 2014 7:02 pm
Ok quick update, had the side grills off, O/S no pipe at all, N/S rubber pipe with joint as described, so I split the joint dug a little deeper and squirted the rear washer, this pipe is the feed for the re washer.
So it appears the moon roof has NO drains and relies on a water tight seal. I found the adjuster screw on each roof latch, there was loads of room fir adjustment, so did so. Now just gotta wait a bit and see if it's now sealing
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by 4x4 bobby on Fri Dec 19, 2014 8:57 am
Just hit it with a hose pipe!!!!
Re: Leaking A series Moon Roof by jaybrian32 on Fri Dec 19, 2014 11:18 am
Hahaha no need, it was Yellow watering down all night, no drips frim the hard top, just gotta dry the carpet out now, cindensation is a pain first thing in the am.
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by 4x4 bobby on Fri Dec 19, 2014 4:02 pm
Well done fella. Bring on the summer!!!!!!! :lol:
Re: Leaking A series Moon Roof by jaybrian32 on Sun Dec 21, 2014 4:12 pm
Hmm a few more drips on the side panel yesterday, added more tension on the clips.
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by jaybrian32 on Mon Dec 22, 2014 9:04 pm
Grrrrrr still bloody leaking! Looks like I'll be buyingsome tiger seal after all
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by yaki on Tue Dec 23, 2014 10:09 am
Looks like I am about to do this as well, SWB has been in the garage since summer, it was parked outside Sunday night and it bleep down with rain and I now have loadsa water coming in :(
Re: Leaking A series Moon Roof by jaybrian32 on Tue Dec 23, 2014 8:15 pm
Ok, added more tension on the adjusters and its rained all day, so far no drips inside........fingers crossed I've sorted it.
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by 4x4 bobby on Tue Dec 23, 2014 9:00 pm
Just one question fella? Have you made sure the seal is clean and the area where the roof seats. I put a good smear of vasalene on mine then shut it and it never leaked. I was also able to remove it in the summer. :thumbup:
Re: Leaking A series Moon Roof by jaybrian32 on Tue Dec 23, 2014 9:06 pm
Yeah, removed the top and cleaned inner and outer seals.....when weather improves I'm gonna remove it again, warm the seals with hair dryer so they regain thier original shape, got a section where the lip has been folded the wrong way. Will treat em to vaseline at the same time.
Touch wood it hasn't leaked today.
jaybrian32
2" Body Lift
Fire Extinguisher
Re: Leaking A series Moon Roof by yaki on Tue Dec 23, 2014 10:04 pm
