Ok discovered my timing belt is very slack, not slipped or come off just slack. Obviously not going to start it till I have fit a new kit and water pump. Can anyone shed light on the part numbers for a 1998 built X20SE?
as far as i know the x20 is the same as most of the c20 and has a tensioner as the duck is an early c20 so tensions off the water pump, and the swan is later and has a tensioner
if anything get a book of lies (hayes manual) and it will take you through it all. it is quite a simple job to change. ive done quite a few now
Modifications: full roll cage snorkle SOA lift winch bullbar winch(ramsey pro 8000) hilift jack mount waffle boards mounts jerry cans mount cb radio front and rear recovery darken leanses 8x spot light rear work light bucket seat 5 point harness
