[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - sheet metal
Any ideas. Where the best place to buy 2mm sheet metal from had a look around on the net but i thought. I'd. Ask just in case i might have. Missed somewhere. Thanks. Mick
Modifications: full roll cage snorkle SOA lift winch bullbar winch(ramsey pro 8000) hilift jack mount waffle boards mounts jerry cans mount cb radio front and rear recovery darken leanses 8x spot light rear work light bucket seat 5 point harness
Best place to buy steel is the scrap yard....many manufacturing places simply weigh in their offcuts, and its worth asking if you can buy some...
You will pay a little over scrap, but can get a selection of materials for a fraction of their new cost, and best of all its cut up for you...8x4 sheets are a pain in the ass to handle and store...
Looks like I'm in trouble with the Mrs's again... She asked me what I'd most like to do to her body... Apparently "Identify it" is not the correct answer!
Modifications: Drive a 2.2dti olympus, 2.8 lwb and 2.0i sport. Breaking... 2.4i and 2.3td 2.0i C20ne and x20se x 4 2.8tdi x2 2.2i A 2.2i B LWB x3 x22dth B dti lwb x3 y22dth B dti lwb x5 Call Fronty4x4spares on 01622 739908. Same day dispatch, next day delivery on 95% of items.
2mm is thick really i only use 2mm cos i have alot of it. i aquired from a job i did.. i would be more likly to buy and use 1.2mm, will be easer to work with
Thin stuff will go with tin snips, thicker a grinder with a slitting disc i guess... I use a guillatine, metal shears or plasma cutter most of the time....or oxy-propane if its proper thick!
I got mine from metals4u but it was a generous order (including 15 meters of cds roll cage tube and 6 meters of stainless hydraulic pipe) no probs with the service and would use again
