suzuki vitara
suzuki vitara by carlisletiger on Tue Mar 25, 2014 8:13 pm
im looking at pulling my engine out to do the oil pump and crank shaft if needed and i have been offered a suzuki vitara for not many pennys as a run around while mine is out of action. its an m reg 1.6 soft top ,anybody know what they are like on fuel ,off road etc? he only wants £200 for it and its mot till august and it is clean so i dont think i can lose on it - (unless i really like it and use it as a toy) :shh:
carlisletiger
Vehicle Name: Tiger
Re: suzuki vitara by Gazeddy on Tue Mar 25, 2014 8:41 pm
front diffs are weak. the soft tops will leak. the engine is solid enough. they are perfectly capable off roaders too with similar suspension set up to frontera
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: suzuki vitara by ianoneill1981 on Tue Mar 25, 2014 10:00 pm
i had a hard top a few years back and it was a good wee motor. not bad on fuel around town and only had it off road once on standard suspension and kingpin treckers and it was pretty good. not to dear to lift when i bought my lift kit then some pillock rear ended me about a week later :thumbdown:
ianoneill1981
Registration Year: 2000/V
Modifications: mg auto springs and cooper stt 31 tyres
Re: suzuki vitara by justdan on Wed Mar 26, 2014 12:11 am
I had. 1 a few years back in a J reg ! 1.6 , it was pants on fuel ( but piston rings were goosed a think ) fun little truck tho
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: suzuki vitara by steve 1967 on Wed Mar 26, 2014 8:28 am
my wife had one for a few years, the fat boy version I think it was, not bad on fuel but like any 4x4 depends how its driven sort of thing, bit chilly in the winter months as I don't think the soft tops are very well sealed, but in the three years we had it, only ever needed a new rad apart from the basic servicing, and for that money I would buy it anyway. :thumbup:
steve 1967
Vehicle Name: JOSHUA
Modifications: 2.5in lift, steel modular wheels, special track tyres, under body protection, tree sliders, winch, snorkel, cb etc
Re: suzuki vitara by gregster on Wed Mar 26, 2014 9:24 am
We have had 4 vitaras come to our woods over the years....all bar one have left with smashed front diffs/shafts.... one after less than 10 minutes!!!
Say no more??? :lol: :lol: :lol:
Re: suzuki vitara by SteveyDee on Wed Mar 26, 2014 12:41 pm
Gregster! Its not funny!!!
Ive had 4 of them and after having a few frontys I wont buy another vitara.
Fuel is about the same as fronty, about as good offroad but the diff is a disposable item :lol:
The engines can crack between cylinders 2 and 3 so dont get the block wet when hot
Have it for 200 though. You can break it for 6-700 if you have the time.
If its not broke, your not driving it hard enough
SteveyDee
Vehicle Name: The Bull
Modifications: 2.2i rs sport (gone)
2.0 sport (gone)
2.8 sport (gone)
3.1td Trooper (Bull) mini monster truck in the making
3.1td vauxhall monterey (monty) for laning
Re: suzuki vitara by Fatbaz on Wed Mar 26, 2014 2:02 pm
For £200 sheets you can't go wrong. Unlifted the front diff third member on moderate tyre survives laning, lifted and on Muds you run the risk of smashing it when the tyre bits after spinning aggresively. Axle housing from an early grand vit fits and is steel instead of alloy. Then you bust CV's, fit axle drop plates to lessen the shaft angle and they get better. Put a Piglet 405 diesel in it and it'll wade a treat and have better grunt.
Or simply use it as a run around til your Fronty is fixed and flog it on for as much or more than you paided for it.
Regards
Stuart
PS, if I hadn't have got the fronty when I did I'd have had one. See "Bits for Vits" forum for the fixes and mods, Daves been running them for years.
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Users browsing this forum: No registered users and 51 guests
