Frontera Technical Support • View topic - Auto for off roading?
Auto for off roading? by BIGMIKE1 on Mon Jan 06, 2014 9:17 pm
Hi
I'm on the look out for a LWB V6 Frontera as a cheap workhorse and to try a bit of off roading, nothing major just a few green lanes and pay&play days to try but as a lot of the V6's are auto I just wondered what people's experiences or thoughts were on using auto's off road?
Mike
BIGMIKE1
Modifications: Trooper HD Springs, 245/75R16 Muds, rear axle breather extended to engine bay, HID's
Re: Auto for off roading? by gregster on Mon Jan 06, 2014 10:40 pm
Auto's are ok off road, what you loose in engine braking you make up for by not having a clutch to burn out. Control is easier on climbs, once you get used to left foot braking without throwing yourself through the windscreen. Regular maintainance I would say is vital though, and keep the tranny cooler clear of mud.
Re: Auto for off roading? by AskDean on Mon Jan 06, 2014 11:48 pm
bang on greg if your going to use it as a tow horse for something heavy you might want to consider adding an oil cooler rad kit in the front for the atf it simple job just unhook the pipes where they go into the bottom of the radiator and then mount a small extra rad youll find them on ebay then plumb the pipes in.
and change your fluid every 10k for optimal performance as the v6 does love to cook the atf fluid and thin it out. if you notice it lurch on pull off and judder on down change then on acceleration seems to miss a beat bewteen changes. just swap the fluid out there is a guide in the how to section take you an hour and it will feel like a new car again.
AskDean
Skype Username: askdean
Re: Auto for off roading? by badsykes on Tue Jan 07, 2014 2:57 pm
I heard the Automatic cars are pretty expensive on maintanance side ? The Automatic box takes more oil...
badsykes
Vehicle Name: KIY
Modifications: STOCK ... except MAF unplugged from time to time for (in)sanity reasons..
Re: Auto for off roading? by geeks on Tue Jan 07, 2014 3:00 pm
Nah not really. From what i have seen from the autoboys other than the autobox taking a different oil to the manuals its pretty much the same!
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: Auto for off roading? by gregster on Tue Jan 07, 2014 3:59 pm
without the headache of killing, cost, and having to change clutches!!!
Re: Auto for off roading? by geeks on Tue Jan 07, 2014 4:01 pm
Indeed, mine is going in at the end of the month for one. £395 all in....
geeks
Stuff...
Also:
Previous:
Re: Auto for off roading? by AskDean on Tue Jan 07, 2014 4:13 pm
the auto box is pretty much bulletproof just change the fliud every 10k and your laughing
and so much more pleasure to drive in the v6 as you stomp and the loud pedal and your gone. no slowing to change gear at pull off so you'll destroy most things off the lights on that we all have when you just feel like wiping the smug look of the not nice in the convertible next to you at the lights blasting his good awful music
AskDean
Re: Auto for off roading? by badsykes on Tue Jan 07, 2014 5:13 pm
AskDean: After "no slowing" i lost myself in your english ...
Someone with a Jeep Cherokee automatic gear box version had a problem with the car being stuck in first gear and not changing anymore..He went to service and they change some computer box..He payed around 600euros...
If there was a 2.0l with auto gear i would give it a try... :angel:
badsykes
Vehicle Name: KIY
Re: Auto for off roading? by Xplorer on Tue Jan 07, 2014 8:35 pm
Both my troopers are autos and have been off-roaded, as Greg said really little less engine braking on down hills ( just have to be a bit braver :lol: )rock crawling is easier can't stall it no clutch to burn out :wink:
Xplorer
Vehicle Name: MadBull
Modifications: Isuzu Bighorn xs auto
TJM winch bumper,
285/75x16 BFG at2,
+2Bloodred spings on rear,
+2 OME Gas shocks
torsion bars raised,
50mm body lift
aisin manual hubs
body decals
limo tints
quad roof spots
Rock Sliders
Family run a round
Isuzu Trooper 3.0ltr citation
2001
7 seater auto
2inch spring spacers
torsion bars raised
265/75 x16 gen grabbers at2
chrome A bar
Re: Auto for off roading? by badsykes on Tue Jan 07, 2014 8:48 pm
Kinda ironic that the 2.0 doesn't have too much engine braking anyway...
Long ago i applied a wrong technics for downhilling: i was putting the gear box in "neutral point" and let the inertia do the job and i just control the steering and gentle handbraking.. When i felt that the car lose power too much then shift in 2nd gear and then press the acceleration again...
I suppose with auto gear box i wouldn't miss the engine braking anyway as i am used from my actual 2.0 with very little engine braking...And i kinda like the idea of braver :)
badsykes
Vehicle Name: KIY
Re: Auto for off roading? by BIGMIKE1 on Tue Jan 07, 2014 9:46 pm
Cheers guys, just wanted to check so I wasn't limiting my search to manuals, I've always loved driving big autos but I'm always wary of autos as an old auto box guy once told me when they go wrong pick a number and add 000 :lol: but as you've said if I can find one with a decent auto box and look after it with oil changes and a separate cooler than fingers crossed should be as reliable as the manual anyway.
Mike
BIGMIKE1
Re: Auto for off roading? by badsykes on Thu Jan 09, 2014 2:48 pm
Hey bigmike...
I liked the joke about the price of auto gear box...Pick a number from 1 - 9 and add three zeros ... :))
I am afraid of those 3 zeros behind ... :mrgreen:
badsykes
Vehicle Name: KIY
Re: Auto for off roading? by AskDean on Wed Feb 05, 2014 4:36 pm
Badsykes you can get a v6 lump for 300 to 600 abs the auto boxes from 400 at 4x4 breakers i used to change the lump as it was cheaper than paying for the head gasket being done lol.
But other than being brave with the brakes for down hill put it 1 and is a fixed gear so you get engine braking.
AskDean
Re: Auto for off roading? by badsykes on Thu Feb 06, 2014 1:15 pm
badsykes
Vehicle Name: KIY
Re: Auto for off roading? by Wilberforce on Thu Feb 06, 2014 3:52 pm
Badsykes, I think Dean has taken your joke about auto box repair costs the wrong way, and was trying to supply helpful pricing information.
He was saying that you can buy a V6 engine (sometimes called a lump) for £300-600, and an auto gearbox for £400.
Also, that when the head gasket needed doing, he would swap engines because it was cheaper for him.
Re: Auto for off roading? by steve 1967 on Thu Feb 06, 2014 7:15 pm
autos are easy once you get to grips with the 4x4 system, select low range and 1st gear for maximum engine braking, if all working properly you should not need the brakes on a steep descent, on a steep climb also low range but 2nd gear and don't be shy with the throttle :D , all obviously much dependant on the terrain. :thumbup:
steve 1967
Vehicle Name: JOSHUA
Modifications: 2.5in lift, steel modular wheels, special track tyres, under body protection, tree sliders, winch, snorkel, cb etc
Re: Auto for off roading? by badsykes on Thu Feb 06, 2014 8:30 pm
badsykes
Vehicle Name: KIY
Re: Auto for off roading? by AskDean on Thu Feb 06, 2014 10:24 pm
Over here there are loads of v6 in bits lol
AskDean
Re: Auto for off roading? by badsykes on Fri Feb 07, 2014 1:59 pm
Is the 2.2DTI automatic more reliable than the manual gearbox version ? I heard that 2.2DTi manuals have a design issue that don't lube properly..
badsykes
Vehicle Name: KIY
