Compressor advice
Compressor advice by justdan on Sun Dec 29, 2013 5:38 pm
Iv a small 25 litre compressor ( the cheap 1 from lidl ) I'm really needing to do some sandblasting with it , just rust from horseshoes , so it's not going to running at full tilt for hours and hours , will it do the job , I think the delivery rate 113 litres a minute ?..........
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: Compressor advice by chrispynuts on Sun Dec 29, 2013 6:21 pm
If you are using the small hand held blast gun that looks like a paint gun then yes in small blasts. You need in excess of 80psig and 20cfm for continuous use (For every 1Hp you get 5cfm approx.)
do not use ordinary sand i.e. builders sand as a blast media you can suffer from an illness called silicatoses same as asbestoses (lungs cant cope with the silicon in sand)
best to use something like aluminium slag, this can be purchased in 20Kg bags you may need to Google to find supplier.
Also best to use face and a breathing mask for protection
Good luck
To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be.
chrispynuts
Vehicle Name: Silver Fella
Modifications: 2"lift with Isuzu Springs @ rear + koni shockers
255X70 General tyres
270,000 miles and on third fuel pump
replaced all fuel lines and all Vacuum pipes
replaced fog lights with 5" headlights (gives me main & dip)
fitted soft nudge bar and spotlights
stage 1 engine remap
Region: Northern Ireland
