'That' Storm... AGAIN!
'That' Storm... AGAIN! by snapper on Sat Oct 26, 2013 9:02 pm
Well, will the Met Office break a habit of a lifetime and actually get a forecast right or is all this palaver on the news just a throw back from the great storm when the Met Office slightly underestimated the weather front headed our way....
Re: 'That' Storm... by Loneranger on Sat Oct 26, 2013 9:49 pm
i'll believe it if I see it.....will be outside working as normal on Monday...
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: 'That' Storm... by BoxCleva on Sat Oct 26, 2013 11:55 pm
Was minding my own business putting a bottom balljoint on the Troop on Friday then out of nowhere this happened :?
It was quite mild 5 mins before it happened .
Re: 'That' Storm... by drinksoptional on Sun Oct 27, 2013 12:37 am
Didnt get a drop all day i managed to rub down fiber glass and spray with primer
Re: 'That' Storm... by Drift on Sun Oct 27, 2013 1:00 am
Its not even a storm yet, its still a computer generated simulation of what might happen :roll: :lol: :lol:
Re: 'That' Storm... by Big Dav on Sun Oct 27, 2013 4:49 am
Were you in a shed hiding then Drinks? ....it was hissin' doon and blowin' a hoolie on the Clyde.
Re: 'That' Storm... by fudge on Sun Oct 27, 2013 9:54 am
well last night a fence at my new house has blown down...
so i will be getting the letting agency to sort that out.
and i have backed the duck close to the house so if anything does happen it should be ok, and the case take most of any trees
Re: 'That' Storm... by snapper on Sun Oct 27, 2013 11:14 am
Nice and sunny here in Brize atm. Think I will cut the grass then the hoolie when it appears tonight can blow all the grass cuttings away :lol:
Re: 'That' Storm... by drinksoptional on Sat Nov 02, 2013 10:36 pm
We got hit by halistones strong winds and thunder and lighting the other day i have never seen weather like it in my life.
Im futher inland now im out Lanark way in heart of the clyde valley which after seen the mount of water is kinda worrying
Re: 'That' Storm... by snapper on Thu Dec 05, 2013 10:15 pm
Good luck to those in the err more stormy parts of the country today...
Re: 'That' Storm... AGAIN! by hipo1024 on Fri Dec 06, 2013 12:15 am
We had a salt bin make a bid for freedom outside halfords today. Was funny because it almost took out my colleague lol. Also a bit of the roof flew in thru the doors shortly after the salt bin incident lol. Only lasted about 20mins tho. The east coast is meant to have it bad tonight.
