These new hubs are a bit funky
These new hubs are a bit funky by gregster on Wed Jul 17, 2013 12:01 pm
Saw these on the bay....no nasty little torx bolts like the avm's, infact no cover bolts at all, which makes me wonder whats involved in fitting the circlips... :shock:
http://www.ebay.co.uk/itm/VAUXHALL-FRONTERA-PAIR-MANUAL-FREE-WHEELING-HUB-91-99-/290362530567?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439af49b07
Re: These new hubs are a bit funky by drinksoptional on Wed Jul 17, 2013 6:33 pm
big hammer if there any doubt or confusion hit it with a big hammer till it fits
Re: These new hubs are a bit funky by country_Est on Wed Jul 17, 2013 9:26 pm
Can always do you a cheap set of fixed hubs off a B if you want them :mrgreen:
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: These new hubs are a bit funky by RatCav on Wed Jul 17, 2013 10:26 pm
I can only assume no circlip ... which means the CV joint will fall out the back of the hub when your on full lock and flexing it.
I think I will stick to Aisin, and AVM.
Edit:
Unless the outer body slides on afterwards. You fit part of the mechanism, put your circlip on. Fit the rest of the working mechanism, then bolt the outer casing on afterwards.
