Syphon
Syphon by alsavs on Sun May 12, 2013 3:48 pm
Im after a syphon to use with oil and fuel there are so many out there and trying to sort out the good from bad im finding to be a nightmare from reading the reviews. So the big question is can anyone recommend a good one to help me out :)
Alan.
alsavs
Registration Year: 1992/K
Modifications: Non as yet
Re: Syphon by 4x4 bobby on Sun May 12, 2013 9:05 pm
Depending how much fuel you wish to move? My mate has got a fuel pump from a scrap yard and wire's it to a car battery and lets it run until the tanks empty.
Re: Syphon by snapper on Sun May 12, 2013 9:08 pm
Remind me not to stand within 50 mtrs of that one if he's pumping petrol bobby... :shock:
Re: Syphon by alsavs on Sun May 12, 2013 9:37 pm
Sounds like a good idea using a old pump. I should have explained a bit more its to drain the fuel and oil from lawnmowers so not a lot. But cheers for the idea 4X4 Bobby :D
Alan.
alsavs
Re: Syphon by 4x4 bobby on Mon May 13, 2013 6:47 am
Why would it be a problem draining petrol with a fuel pump that's designed to pump petrol in the first place cant see the logic in that one? You don't put the pump down the tank hole you put a pipe so there is no open electrics near the fuel.
http://www.ebay.co.uk/itm/12V-ELECTRIC- ... 3cc86f3d7a
This one is ideal as it can be mounted to a block of wood to hold it still.
Re: Syphon by alsavs on Mon May 13, 2013 10:04 pm
Cheers for the link 4x4 bobby :D
Alan.
alsavs
