2 stroke oil in fuel
2 stroke oil in fuel by Marcus on Tue May 07, 2013 9:58 pm
A lot of discussion among the derv burning BMW owners I know about using a little of the above in their fuel, reasoning it lubricates the pump a little and other goodness, anyone tried it on a Fronty ? :?:
Power is nothing without control.....
Marcus
Re: 2 stroke oil in fuel by john (smifffy) on Thu May 09, 2013 6:25 pm
I think drift has been using it for about a year or so
Re: 2 stroke oil in fuel by manny on Thu May 09, 2013 6:41 pm
Ye does help i have been using for a year now putting about 150ml every tank
manny
Modifications: Wheel spacers
Re: 2 stroke oil in fuel by Drift on Thu May 09, 2013 7:01 pm
I bang in 250ml per tank full, works a treat.
The old diesel engine fuel pumps where designed to be lubricated by sulphur in the fuel but the sulphur has been phased out in fuels and replaced by an alternative. This is fine for new pumps designed to run on the stuff but its not as good for old pumps and they can get a bit noisy, so the 2 stroke contains sulphur and is an ideal replacement.
Only use mineral 2 stroke and not synthetic 2 stroke as this will cause issues.
Re: 2 stroke oil in fuel by Marcus on Fri May 10, 2013 1:06 am
Cool, I will grab hold of some mineral 2 stroker oil then, any brand you recommend or supplier Mr D ? :wave:
Marcus
Re: 2 stroke oil in fuel by Wilberforce on Fri May 10, 2013 1:38 am
I'm in the same camp as Drift... pour a little into my tank each time I fill up. I go for about a third of a litre mind.
Just use Asda own brand 2-stroke oil, pick up a bottle when needed.
Re: 2 stroke oil in fuel by Hound Dog on Fri May 10, 2013 9:39 am
I'm also in the same camp as Drifty and Wilberforce I use ASDA's own 2 stroke.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: 2 stroke oil in fuel by Marcus on Fri May 10, 2013 10:23 am
TY :)
Marcus
