2.2 dti, is it any good?
2.2 dti, is it any good? by dcy on Sat Apr 06, 2013 11:15 pm
Looking for another swb, ideally want a 2.8 but seem very hard to acquire so next Option is the 2.2. What are they like, will mostly be used for off road use. Any other lumps I should look at?
dcy
Vehicle Name: Chugga bug
Modifications: 2" shackle lift, 31" rubber vanilla air freshner!!!
Re: 2.2 dti, is it any good? by Dannyboy on Sun Apr 07, 2013 10:46 am
Ask STEVD hes got one with 200k+ on and doesnt take to much care of it :lol: and its still goin strong pal..
Re: 2.2 dti, is it any good? by geeks on Mon Apr 08, 2013 8:59 am
Have a 2.2 DTi LWB. Cracking engine with a good pull. Drags things around like the arent there most of the time. Other than a service and a few other consumables mine has been on the button engine wise. Always better to find one that has had the fuel pump replace if you can. Yet to test its mettle fully offroad but the little bit i have done it has swallowed up, seems to run up steep inclines like they arent there... From what i have seen they are no less capable than a 2.8...
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: 2.2 dti, is it any good? by fudge on Mon Apr 08, 2013 9:49 am
if it is mostly off road do you want a swb or lwb?
as a 2.4 seams to fair well with greg
Re: 2.2 dti, is it any good? by dcy on Mon Apr 08, 2013 10:25 am
Only interested in swb really. Have no need for Lwb really. Glad to hear that about the 2.2 as the 2.8 is not easy to find.
dcy
Re: 2.2 dti, is it any good? by Dannyboy on Mon Apr 08, 2013 5:23 pm
Ive got a 2.5tds and I think its awesome, good on fuel even if I do run it on chip fat!!;) and pulls well, also not had any probs off road, and I'm not one for holding back!! :lol:
Re: 2.2 dti, is it any good? by Wilberforce on Mon Apr 08, 2013 5:25 pm
Yes, but the 2.5 powered SWB is even less common than the 2.8 SWB.
Re: 2.2 dti, is it any good? by dcy on Mon Apr 08, 2013 7:15 pm
Got to admit, I'm struggling to find many diesel shortys within budget and distance. Found two 2.8's but both are nearly 200+ miles away!!
dcy
Re: 2.2 dti, is it any good? by hipo1024 on Mon Apr 08, 2013 7:42 pm
The 2.2 dti's are a good bit of kit! And have loads of powerrrrr lol. See some of the vids from last years annual to see what they can do. The 2.8s only real advantage (and the reason I sold my DTI for a 2.8) is that it has no ecu...so oops...that puddles a little deeper than I thought isn't such a problem as long as you have a snorkel :P. Also as said above...on the 2.2 DTI look out for ones that have had the fuel pump changed recently... Other wise budget an extra 500 to get it fixed as and when it goes fup lol
