Engine holding back at 2900rpm
Engine holding back at 2900rpm by andytats on Sat Mar 30, 2013 5:23 pm
As there is no area for a lr discovery I've posted it here :lol:
Yes I know this is a frontera forum I would ask on the lr forum but I've had enough of the analey retentive reply you get on that one.
As i was driving to stretch & gem's today the car was running fine then it started to play up.
it feels like its holding back at 2900rpm in all gears when it does that I get a lot of black smoke out of the exhaust. I'm not sure what is up yet as I haven't looked. Any help would be gratefully received
It idles fine at just below 900rpm even when it's stationary you can't rev it past 2900rpm
Air box & filler are clear
It has oil & water
Has diesel
No eml light
I don't have a code reader
Engine is a 2.5 diesel
Re: Engine holding back at 2900rpm by andytats on Sat Mar 30, 2013 6:30 pm
No sensor on the air intake
Re: Engine holding back at 2900rpm by Drift on Sat Mar 30, 2013 6:33 pm
Revs holding back could indicate air getting into the fuel system.
Re: Engine holding back at 2900rpm by andytats on Sat Mar 30, 2013 8:33 pm
I'll check all the fuel lines tomorrow and the injectors
Re: Engine holding back at 2900rpm by chrispynuts on Sun Mar 31, 2013 11:32 am
Possible Swirl valves in inlet manifold not opening, restricting air flow into engine
To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be.
chrispynuts
Vehicle Name: Silver Fella
Modifications: 2"lift with Isuzu Springs @ rear + koni shockers
255X70 General tyres
270,000 miles and on third fuel pump
replaced all fuel lines and all Vacuum pipes
replaced fog lights with 5" headlights (gives me main & dip)
fitted soft nudge bar and spotlights
stage 1 engine remap
Region: Northern Ireland
Re: Engine holding back at 2900rpm by andytats on Sun Mar 31, 2013 3:06 pm
Well just been looking at the car looks like I have bought another car that defies the laws if physics :lol:
I drained the sediment tank of the crap
Checked the fuel filler and injectors then the air intake all of that was fine. So all I could think of next was the glow plugs took the first one out then connected it straight to the battery it only just got warm (didn't glow) so then checked the rest. All 3 didn't even get warm. So how can I car sound fine on idle and drive when only one glow plug works :shock:
Ordered a new set of plugs so once I have them I'll try it again
Re: Engine holding back at 2900rpm by Drift on Sun Mar 31, 2013 3:12 pm
Glow plugs only operate on cold starts, they wont be your issue :wink:
Most cars will start without glow plugs in this country, just a bit more cranking and smoke from unburnt fuel :lol:
Re: Engine holding back at 2900rpm by andytats on Sun Mar 31, 2013 3:15 pm
I'm at a loss then as to what is wrong
Re: Engine holding back at 2900rpm by Drift on Sun Mar 31, 2013 3:17 pm
Has your fuel filter been changed recently?
Re: Engine holding back at 2900rpm by andytats on Sun Mar 31, 2013 3:19 pm
Yea that was replaced about two months ago. I will order a new one just incase
Re: Engine holding back at 2900rpm by Drift on Sun Mar 31, 2013 3:23 pm
May not need a new one, check the lines as they may be letting air in and you say you checked the injectors for leaks, is the turbo boosting up?
Re: Engine holding back at 2900rpm by hipo1024 on Sun Mar 31, 2013 4:08 pm
You said there's no eml, does that bulb work :P sounds like it might be in limp mode if LRs have such a thing. I assume you have checked the turbo? Could be fuel pump advance is playing up, does it only do it once its warm or does it do it even when stone cold? My thoughts are black smoke is too much fuel and not enough air, so can only really be turbo related or fuel pump/injector related. Or a sensor that controls either of them. Does it have a crank position sensor, when mine went in the DTI it wouldn't rev for love nor money and just smoked a lot...but it wouldn't idle steady either.
Re: Engine holding back at 2900rpm by andytats on Sun Mar 31, 2013 4:15 pm
The Turbo seems to be working well it did yesurday. I can start the car no problem but its only idleing at about 750rpm and sounds like its only running on two cylinders then as soon as I use the loud pedal the engine dies. I've now given up on it until the new glow plugs turn up
Re: Engine holding back at 2900rpm by Drift on Sun Mar 31, 2013 4:20 pm
My gut feeling is air in the fuel lines or leaking injectors.
Re: Engine holding back at 2900rpm by Dannyboy on Sun Mar 31, 2013 4:26 pm
Maybe you could throw a couple more logs into the burner and see if that helps mate! :lol: :lol:
Seriously tho, my mates got a 300tdi and had a problem similar and it was summat to do with his turbo?? may be worth a check? :?
Re: Engine holding back at 2900rpm by chrispynuts on Sun Mar 31, 2013 4:34 pm
It is air supply TRY the Swirl Valves in the inlet manifold they may be stuck shut not allowing enough air in at higher revs !!
Sorry I have just read your profile I was thinking about a 2.2
chrispynuts
Re: Engine holding back at 2900rpm by hipo1024 on Sun Mar 31, 2013 4:36 pm
Maybe worth checking the timing and belt...might have jumped a tooth or two. If its running that bad now I can't believe there's still no eml!
Re: Engine holding back at 2900rpm by andytats on Sun Mar 31, 2013 4:49 pm
There isn't any swirl valves in the inlet manifold I know this because I took that off 2 weeks ago to clean all the gunk out.
I will try the new glow plugs if its still running the same then I will remove all the air pipe and manifold then check the turbo. I've already looked at the fuel lines and they look fine. With the glow plugs out I cranked the engine over and I'm getting a fine mist of diesel out of all four. So the fuel pump and injectors are fine.
Re: Engine holding back at 2900rpm by hipo1024 on Sun Mar 31, 2013 4:51 pm
EGR fault if you haven't already removed it? Or possibly the blanking plate leaking if you have removed it. Completely forgot about that lol
Re: Engine holding back at 2900rpm by andytats on Sun Mar 31, 2013 4:54 pm
Egr has been blanked off
