Starting issue with van.
Starting issue with van. by jimmybhoy on Fri Mar 29, 2013 9:55 pm
My Abs light came on unexpectedly about a week ago, all seemed ok, i thought it may be a dodgy sensor. Put it on the things to do list & didnt give
it any more thought. I went to start it @ lunchtime & it seemed a bit slow, but started & off i went. I was in and out 3 or 4 times today & all seemed fine.
Tonight i went for a take away, when i left shop to start van it was dead.....absolutely dead. Jump started and it went fine & got me home, it will be the
same in the morning, no doubt. Anyone any ideas if it would be battery or alternator. The latter was replaced with the Rac just under a year ago next week.
jimmybhoy
Registration Year: 2004/04
Re: Starting issue with van. by Drift on Fri Mar 29, 2013 10:41 pm
It may help if you reveille the make and model of the van :thumbup:
Re: Starting issue with van. by jimmybhoy on Fri Mar 29, 2013 11:07 pm
:oops: having one of those days. 55 Citroen Relay 2.2
jimmybhoy
Re: Starting issue with van. by Gazeddy on Fri Mar 29, 2013 11:22 pm
right that engine is actually a ford one. that engine will run provided it has sufficient fuel pressure (230 bar cranking) and crank and cam timing are syncronised.
sadly you cant tell this if you dont have specialist gear. id lean towards battery as once its running its fine. but check the wiring to the three pin plug on the transit the wiring breaks up and causes no charge issues
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
