Best off the shelf engine cleaner fuel additive?
Which engine cleaners are the best for adding to the fuel?
I've been told molyslip all the way for oil in different parts of the truck but wondering about the fuel stuff.
taylor6632
In the fuel I use 250ml of mineral 2 stroke oil per 80l tank.
does that clean injectors too?
taylor6632
It helps.
The 2.8 and older designed diesel engines where designed to run on fuel with sulphur in as lubrication for the pump but new emission rules phased out most of the sulphur in fuels years ago and replaced them with other additives. Adding the 2 stroke quietens the pump down and does clean the system out a bit and can occasionally return better mph ever so slightly.
Ok, so something like this
http://www.halfords.com/webapp/wcs/stor ... yId_255223
On a full tank?
taylor6632
or this is better?
http://www.diy.com/nav/garden/garden-po ... Id=9228868
I got a trade point card there so its cheaper anyway
taylor6632
As long as its mineral and not synthetic it should be fine, I use Asdas oil :lol:
sounds good to me. I'll get some of that or similar.
taylor6632
Could i do the same in the 2.2DTI? Or will the less agricultural engine not like it?
taylor6632
