[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Anybody want to buy a kidney ??
Modifications: full roll cage snorkle SOA lift winch bullbar winch(ramsey pro 8000) hilift jack mount waffle boards mounts jerry cans mount cb radio front and rear recovery darken leanses 8x spot light rear work light bucket seat 5 point harness
Selling my wife wouldn't raise anywhere near enough even if I could find anyone daft enough to even consider it!!!!!!!! Couldn't even give her away, not even to charity.
Modifications: Extended axle and transmission breathers. Suspension lift curtesy of TJM +2 springs +2 Rough country shocks curtesy of Llama 4X4 Mitsibushi L200 wheel (16x7 10mm offset) Hankook RT03 285/75R16 Long wheel base light conversion 50mm body lift Twin Electric rad fan conversion Roof mounted waffle board rack with boards Light bar with Lights and CB ariel mount Custom built winch bumper to suite Body lift Tmax 11000 lbs winch with external and incab controls. Aisin Manual Hubs
