If they are alloys I would tend to go for bead blasting sooner than sand as it can be pretty prutal on the alloy... In honesty its not neccesary normally though, and I do loads of wheels... 80 grit out any flakey bits and feather in with 180...then etch prime and apply several thick coats of hi build primer (2k is better, like lechler green Ti)... then guide coat and block out, stopper any imperfections and flat out and hi build again, guide coat and block out, degrease, panel wipe, tack off and base and clear them...job done.
Looks like I'm in trouble with the Mrs's again... She asked me what I'd most like to do to her body... Apparently "Identify it" is not the correct answer!
Modifications: Drive a 2.2dti olympus, 2.8 lwb and 2.0i sport. Breaking... 2.4i and 2.3td 2.0i C20ne and x20se x 4 2.8tdi x2 2.2i A 2.2i B LWB x3 x22dth B dti lwb x3 y22dth B dti lwb x5 Call Fronty4x4spares on 01622 739908. Same day dispatch, next day delivery on 95% of items.
So a quick squirt from an old can of Hammerite won't do then?
Work safe, and remember all technical problems can be resolved with a hammer, the trick is knowing where to hit it and how big a hammer to use (I often find it may also help to have a spare bit in the shed to replace the bit you have just mullered )
