Battery top up
Battery top up by Retro Pedro on Fri Jan 25, 2013 2:03 pm
Done my electric fork lift top up course yesterday (for company insurance purposes) and the instructor came out with this one.
Apparently, I would need to charge a battery up first, then when fully charged and if required, top up with distilled water.
Explanation given was that whilst charging, the liquid expansion process will occur giving off a gas. If top up occured after charging, the distilled water would then be at the correct level.
What do you reckon, true or false?
Re: Battery top up by Rich on Fri Jan 25, 2013 3:57 pm
I think he is correct i remember topping up a battery and then charging it and the finding the fluid over flowing while it charged.
Re: Battery top up by fogman on Fri Jan 25, 2013 7:30 pm
i thought the electrodes had to be just covered before charging
Re: Battery top up by Drift on Fri Jan 25, 2013 7:34 pm
I work for Linde fork lift trucks, we just top them up and charge them and top up after if needed, this is 24v, 48v and 80v batteries.
We also build/refurbish batteries and its not as technical as you may think, lots of hammering involved :lol:
Re: Battery top up by Lenny1969 on Tue Jan 29, 2013 1:21 pm
Instructor is wrong. I'm an FLT instructor and national examiner and what should be done is battery topped before charging to allow for equalisation charge to pulse fluid from water into electrolyte, otherwise all you are doing after charging is diluting the electrolyte thus shortening the battery length time.
In Consilio Sapienta
Lenny1969
Modifications: Looking for the right Fronty.
Re: Battery top up by Drift on Tue Jan 29, 2013 2:26 pm
If the cells look dry or you can't see the water then fill and charge then top up and test.
