Clio head gasket trouble.. Plus useful generic advice.
Did my little brothers head gasket on a 00 1.2 8valve Clio just over a year and a half and 14,000 miles ago and low and behold, its gone again.... :evil: Huge pressure build-up from start-up, oil has gone a dark brown, steam galore when you remove the oil cap etc etc etc....... Im a mechanic myself and I was told at the time I could take as long as needed so it got a full head set, new bolts, new pump, belt, thermostat, auxiliary belts, cam and crank seals, reground inlet valves, rePLACED exhaust valves (Bloody bench grinder wouldn't have saved them!!) And much more. Head was also skimmed and block cleaned. It continued to burn oil after even though compression was perfect so stripped again and replaced the piston rings and by extension, big-end bearings (Job was done withoutremoving engine as was very very pressed for time.) Head was cleaned with the skimming machine as opposed toskimming as the head was perfect under a straight edge. Once again block cleaned and new gasket and bolts. Worth noting was that, rather than break, the old rings could literally be bent into pretzels! :shock: Rings should snap so I reckoned i might have it licked! :drink: It STILL burned oil :roll: Turned out the pcv filter disintegrated and blocked the oil drop section, sending vapour and oil to the throttle body where it was burned with the air/fuel mix. This happens in quite a few types of vehicle actually and i did suspect it but the rings, bearings, bolts and gasket were a third of the price of the rocker cover pwhich was only obtainable from a dealer... Oh well, New rocker cover and everythings been peachy. Till now.. Im going to strip it again this week, I figured I'd ask any gurus here if theres something I should look for, outside the box? I'd hate to think I messed something up the oast time.. Sorry for the mega-story, maybe itll kill some time for ye! All the gaskets I've done, all the ones ive just botched, upon request, just to get someone out of a hole, and its this one that bellies up :roll:
"The door won't open."
"Fine, we're stuck.."
My Frontera:)
viewtopic.php?f=115&t=51836&p=558224#p558224
Renegade
Vehicle Name: Isabel
Modifications: Just tyres and a pair of Aisin manual hubs for now:)
Re: Renault Clio head gasket trouble.... by Renegade on Tue Jan 01, 2013 3:59 pm
It's happened all of a shot too, because I checked the levels of all fluids three weeks ago! And the coolant was perfect, oil was as black as 5,000 ml old oil should be and still at the top mark! It does some motorway miles lately so the old girl is grounded for now :)
My Frontera:)
Renegade
Re: Renault Clio head gasket trouble.... by manny on Tue Jan 01, 2013 9:31 pm
You need to check the hight of the liners they are spacered and there is a seal at the bottom of them aswell if the seal has worn the liner drops and head gasket problems or starts burning lot of oil we had a problem at work were one of the lads did his own car and after use a1l every 100miles of oil
manny
Modifications: Wheel spacers
Re: Renault Clio head gasket trouble.... by vauxsqueeks on Wed Jan 02, 2013 2:31 am
Someone at work my last year who had one of these cars ( 1998 'S' Clio 1.2 8V ) were driving on the motorway and the cambelt snapped. This was the result.
They needed the car but couldn't pay the £800 garage quote... also the car was not worth it. so I said that I would help out and ended up rebuilding the head, new gaskets and did a full service. All for less than £280 in parts. This was done and the car has covered a few thousand miles now since and is still running well ( surprise myself sometimes! ) I had never worked with tappit's before. 8)
@Manni: I don't remember the engine having liners??
@Renegade, sounds like you did a thorough job.. don't know why its gone again though.
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: Renault Clio head gasket trouble.... by Renegade on Wed Jan 02, 2013 3:12 am
Sorry manny, solid block on these ones. I wasn't aware that liners can wear down though!! Glad I'm still an apprentice :oops: Will keep that in mind for future jobs of the rover variety heh heh heh! And nice pics vauxsqueaks, So the 8v Clio IS an interference engine.... good to know :lol: Ive just finished stripping it this evening. (We decided the sooner the better, he'll manage!) The metal ring section on the gasket for the first cylinder has blown away around a fracture. Will upload some pics tomorrow under "general" guise :D also noticed is some "Punto style" charring between cylinders 2 and 3 even though the corresponding areas on the block and head are not burned. Thermostat opens when heated and and pump impeller is strongly attached to its shaft. Even the radiator is free and its fan working. Not impressed with the gasket just failing like that I have to say but at least it's mystery solved. 2013 eh? :roll: Now then, satisfied with my :drink: and my sky plus recording of man uniteds win I think it's time for some well earned kip!!!
My Frontera:)
Renegade
Re: Renault Clio head gasket trouble.... by gregster on Wed Jan 02, 2013 4:04 am
This might sound daft, but it hasnt got one of them stupid oil coolers on the filter housing has it? Easy to spot as the oil filter housing has to coolant hoses going to it...
The reason I say this is as "back in the day" I used to buy loads of 16v Gti golfs and passat GTi's with "headgasket" failures, when it was only the oil cooler that was goosed.
Long shot, but if its got one it might be worth eliminating.
Re: Renault Clio head gasket trouble.... by adyclemo on Wed Jan 02, 2013 10:17 am
Engine block warped slightly, we had this with a peugeot diesel many years ago.
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: Renault Clio head gasket trouble.... by Renegade on Wed Jan 02, 2013 7:20 pm
Coolant fed oil coolers are featured on later K and F engines but thankfully not on these Ds gregster! And block is uniform under the straight edge, Ady, thanks for that one. Here is the offending gasket.
Notice the burnt bridge between clyinders 2 and 3. Also those cylinder rings are ok but the number 1 and 4 cylinder rings are not withstanding the coolant and are nowhere near as clean.
Now a close up of the blown number 1 cylinder ring.(4 in Renault speak, orders are reversed...)
The ring failed and gasses at 1100 degrees celcius @ probably 400 psi made a path into the coolant jacket with ease. When parked, the pressurized coolant is forced back into the cylinder, making its way past the pistons, into the oil. Lucky people will have the water invade the cylinder at the beginning of that cylinders compression stroke and the vehicle won't start easily. When it does, only the blind will fail to notice what will appear behind the car.... Any how the water in the coolant turns into steam, rising to the top of the engine and clinging to the oil there, mixing, and creating this mess..
That mess gets bigger until it gains enough mass to fall off the rocker cover and mix with the oil, Which is one way the cooling and oil mix but thankfull in this case, at a much slower rate.
This it the cylinder head.
The exhaust valve on the water effected cylinder is a darker shade of red/brown. I can test the seal of all four chambers by simply turning it upside-down and filling each pot with petrol. The petrol will not drain if the seal is perfect. But petrol WILL find even microscopic discrepancies!
And now a useful tip to anyone suspecting foul play as this type of head gasket failure is notoriously hard to detect before the chance of heavy damage raises significantly. While servicing. (Remember, you car hasn't boiled over/ seized yet so actually checking the coolant for bubbles while running the engine may not occur.) Have a good looi at your spark plugs before throwing them away. If one of them looks like the first one here:
Then, friend, youre burning coolant :wink:
Lastly, look at the difference between pistons 1 and 4
That is a steam cleaning! :lol:
My Frontera:)
Renegade
