Frontera Technical Support • View topic - Pre-MOT fail
Pre-MOT fail
Pre-MOT fail by frontera2010 on Fri Dec 28, 2012 5:14 pm
frontera b s reg 2.2i 16v petrol 3door
pre-mot fail list
1. washers INOP
2. driver seat loose
3. No plate lamp INOP
4. rear axle tie bar Bolt loose
5. n/s Outer sill holed
6. o/s outer sill holed
7. exhaust center mount missing
8. Fuel Tank Filler Pipe holes
9. n/s/r Brake bind
10. n/s/r brake pads worn out
11. n/s/f and o/s/f Brake pipes
12. o/s/f Brake flexi insecure ( bracket broken)
13. o/s/f CV to hub Loose
advise
1. battery Insecure
2. Switch on Steering Colm Insecure
3. o/s/f Drop Link Worn Ball Joint
4. n/s inner D bush worn (anti roll bar)
5. rear brake comp. spring plastic retainer-separated from spring (will re-fit)
so what you think should i go repair it or what?????
frontera2010
Registration Year: 1999/S
Vehicle Name: monster 4x4
Modifications: offroad tyres 235/70r16
3inch suspension lift
4 spot light on roof
cb aerial on spare wheel holder
Re: Pre-MOT fail by BoxCleva on Fri Dec 28, 2012 5:19 pm
Re: Pre-MOT fail by frontera2010 on Fri Dec 28, 2012 6:32 pm
well i can do all but i dont have welding kit so my mate can do for me would be 100 to 125ish for both side sills
it small stupid things to repair lol... been offroad for while and the owner use as offroad farmer so now would be goo if get passed mot and get on road...
i cant belive that the bracket bent on o/s/r chassis bracket for the side bar to axle will try get photo of that
frontera2010
Re: Pre-MOT fail by gregster on Fri Dec 28, 2012 6:52 pm
Re: Pre-MOT fail by Drift on Fri Dec 28, 2012 6:57 pm
Oi Southerner, no tech talk here :butt: :dance: :dance:
Re: Pre-MOT fail by gregster on Fri Dec 28, 2012 6:58 pm
Sorry boss... :oops:
Re: Pre-MOT fail by Drift on Fri Dec 28, 2012 6:59 pm
Gottcha :naught: :v happy:
Re: Pre-MOT fail by snapper on Sat Dec 29, 2012 2:48 am
Save the cash on the welding, add a bit to it and go buy a gasless mig and a handgrinder from Machine Mart. Get some scrap bits from the scrap yard and have a go. Then do the sills.
You will also need a Welding Mask, in which case get one of the modern self darking ones, tis easier with one of those.
