Frontera Technical Support • View topic - oil additives
oil additives
oil additives by carlisletiger on Wed Nov 21, 2012 7:47 am
so whats everyones opinion on the best oil additive ? Ive always used Wynn's but just wondered if anyone can recommend anything better ?
carlisletiger
Vehicle Name: Tiger
Re: oil additives by Wilberforce on Wed Nov 21, 2012 8:24 am
Molyslip engine protector in the engine and gearbox (one bottle in each) and molyslip gear protector in the diffs (Unless you have an LSD, in which case that's a bad idea) works for me.
Re: oil additives by Dannyboy on Wed Nov 21, 2012 8:05 pm
2nd the Molyslip :thumbup:
Re: oil additives by gpssti4 on Thu Dec 06, 2012 8:07 am
Don't bother. They are a waste of time at best and at worst promote engine wear/damage. I work for a large diesel manufacturer and we won't recommend any. Stick with good quality oils and frequent oil changes.
gpssti4
Registration Year: 2004/04
Re: oil additives by 4x4 bobby on Thu Dec 06, 2012 8:35 am
Sorry mate I totally disagree Molyslip reduces wear and protects all metal parts. A guy on this site lost a sump plug and still managed to drive home without damage to his engine only because he had put Molyslip in it. everyone has their own opinion. All you have to remember is change the oil after a couple of thousand miles as the filter will have done its job and now become US. It makes the engine quieter aswell. Older vehicles can benefit from such additives. There are a lot of members on vehicle forums that do recommend oil additives and those that don't.
Regards Bobster.
Re: oil additives by Drift on Thu Dec 06, 2012 9:24 am
Bob I was out with that member when his oil vanished, that was about four or five years ago and that car (2.8) is still going strong :wink:
I use molyslip and it does get the 2.8 a bit quieter.
I have also been throwing non synthetic 2stroke oil in my diesel and this lubes the pump :wink:
Re: oil additives by 4x4 bobby on Thu Dec 06, 2012 9:36 am
Say no more!!!!!!! :thumbup:
Re: oil additives by BoxCleva on Thu Dec 06, 2012 9:40 am
The only additive I use is holy water. Sprinkle a bit on the bonnet , make the sign of the cross and pray the fricken thing starts :thumbup:
Re: oil additives by Drift on Thu Dec 06, 2012 10:05 am
:lol: :lol: :lol:
Re: oil additives by 4x4 bobby on Thu Dec 06, 2012 10:46 am
Thought you got a proper Fronty now (Shorty) Si ??????? :mrgreen:
Re: oil additives by geeks on Thu Dec 06, 2012 1:14 pm
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: oil additives by gpssti4 on Mon Dec 10, 2012 7:50 am
gpssti4
Re: oil additives by 4x4 bobby on Mon Dec 10, 2012 9:30 am
Im sorry but the guy who say's claims of running with an empty sump are frudulent is a dickhead as we know its happend and Ste was with the bloke who did it. And since the start of these additives they have been developed to be better than when usin parafin! Technology has moved on in leeps and bounds since the first development.
Re: oil additives by carlisletiger on Mon Dec 10, 2012 7:40 pm
well ive just chucked molyslip in mine and the difference in engine noise is remarkable . you can hardly tell its running now ,and yes i have checked that it is actually running (it been a 2.2 after all).
will probably be doing the head again shortly ( it been a 2.2 after all ) so will let you all now what the engine is like when i get to see inside it again :D
carlisletiger
Vehicle Name: Tiger
Re: oil additives by 4x4 bobby on Mon Dec 10, 2012 10:07 pm
Keep us posted fella and we will need pictures when it does go!!! :thumbup:
Re: oil additives by Drift on Mon Dec 10, 2012 10:23 pm
It quietens down my 2.8 a fair bit, the 2stroke helps in the fuel for lubing the pump too 8)
Re: oil additives by Keefy D on Thu Feb 21, 2013 1:04 pm
Just read this post and back in about 1992 - 93 I was living in west bromwich & working in rugby 70 mile round trip traveling every day, car at time a 1990 montego turbo diesel on part synthetic with slick 50. Basically had timing belt changed of a friday picked up sat morning sat afternoon oil light on :shock: checked oil level all ok checked pressure switch as in area of belt incase of damage when belt changed replaced it still same, elec fault maybe. Went to work mon morning all ok carried on till wednesday speeds around 80-90 where possible. Thirsday morn just got on M6 J7 rattle bang oh dear :shock: into rover dealer dignostic, oil pump failer. No oil had acctually been around the engine since the light came on of the saturday. So I would recomend additives :D
Knowledge may be one thing but You Cant Teach Experience...
Keefy D
Vehicle Name: Rattler
Re: oil additives by taylor6632 on Thu Feb 21, 2013 1:18 pm
Drift, how much 2 stroke oil do you put in per quater tank? i like the ideal of giving the fuel pump some love :D
taylor6632
Re: oil additives by Drift on Thu Feb 21, 2013 1:51 pm
I pop in 250ml per 80litres :-)
