Frontera Technical Support • View topic - Who can solve this one (My van)
Who can solve this one (My van) by jimmybhoy on Fri Nov 16, 2012 8:28 pm
Citroen Relay HDI 2.2 ....... Last week dropped a gear to turn a corner, then no power & lots of black smoke. Still runs & starts when switched off just wont rev high. New egr valve, egr solenoid control pump, all is good for 2 happy days.
Tonight on way back from hospital visiting, same again no black smoke this time though. No dash warning lights either. :?
jimmybhoy
Registration Year: 2004/04
Re: Who can solve this one (My van) by Dannyboy on Fri Nov 16, 2012 8:47 pm
HDI engine mate, my guess is the injectors are fubar :thumbdown:
Re: Who can solve this one (My van) by Drift on Fri Nov 16, 2012 8:53 pm
Injector or turbo :wink:
Re: Who can solve this one (My van) by BadBoy on Fri Nov 16, 2012 10:01 pm
If it's the same engine found in a 2001 Peugeot Boxer diesel then from personal experience......fuel filter :wink:
May not sound right, but I had a company one in 2003 which did exactly what your describing. It was pouring out black smoke big time.
Turned out to be the fuel filter. Dealer was able to diagnose over the phone too so must be a common problem.
Got it towed into the dealer who fitted a new filter straight away and no more black smoke or loss of power. Was back on the road 10min later.
Skype Username: paul.bush21
Re: Who can solve this one (My van) by manny on Fri Nov 16, 2012 10:51 pm
Intake butterfly sticking or spring come off
manny
Modifications: Wheel spacers
Re: Who can solve this one (My van) by jimmybhoy on Fri Nov 16, 2012 11:46 pm
Cheers Guys for the usual good advice. I was thinking fuel related, as it goes in wee bursts. Will have a browse tomorrow.......whats the betting its piddling down :boohoo:
Reason: this aint the lounge ;-) no swearing
jimmybhoy
Re: Who can solve this one (My van) by dt1968 on Sat Nov 17, 2012 12:29 am
a faulty" air flow meter" gives the same problem as your having.... and doesnt allways thro up a code u can read :wink:
2.8tdi lwb.... 2"lift.. 31.10 15s snorkel cb
dt1968
Modifications: 2" spring lift. .cb .torsion wind up. snorkel .2"bodylift
31.10.5 15s
Re: Who can solve this one (My van) by jimmybhoy on Sat Nov 17, 2012 12:58 am
had a new one of them as well.
jimmybhoy
Re: Who can solve this one (My van) by Dannyboy on Sat Nov 17, 2012 12:08 pm
im still going for injectors.
Re: Who can solve this one (My van) by manny on Sat Nov 17, 2012 7:25 pm
how old is it as if it new ish and running the 2.2 hdi/ ford engine not pug engine the could need ecu resetting for egr/ download i havent worked for pug for 3 years now but we had loads of downloads and replacement egr valves when ford engine come out.
pug engine would go fuel/air intake
ford software/egr
manny
Re: Who can solve this one (My van) by jimmybhoy on Sat Nov 17, 2012 10:35 pm
its a 55 plate Manny.
jimmybhoy
Re: Who can solve this one (My van) by manny on Sun Nov 18, 2012 11:20 pm
it should be the pug engine then check the inlet butterfly if it loose then thats the fault there are also to actutors the work on vacum they are under the big cover right at the top of engine bay two 10mm to get it of one does egr other does turbo i think. these vans are a pig to diag as they are a mix pug engine fiat body
manny
Re: Who can solve this one (My van) by jimmybhoy on Tue Nov 20, 2012 8:32 pm
Thanks very much for all the info troops, much appreciated :clap: . it was the fuel filter :drink:
jimmybhoy
Re: Who can solve this one (My van) by RatCav on Wed Nov 21, 2012 8:24 am
Easy fix then. Nice one 8)
Re: Who can solve this one (My van) by BadBoy on Wed Nov 21, 2012 3:03 pm
