For the best part of this year I've done doing the last couple of years 'to do list' jobs.
Although engine is running, car isn't. Steering bottom linkage arm etc and front diff swap still to do. So in the meantime, routinely start the engine every couple of days. Tonight I started it up and initial thoughts are that it sounds alot quieter and smoother. Along with a passing neighbour, even the wife commented how quiet it sounds
Jobs recently done are:
Adjust tappets
Renew glow plugs
Blank of EGR valves
Replace turbo
Put 225ml of 2 stroke engine oil into the 3/4 tank of diesel.
Reckon it's tappets that have made the difference because all 8 needed adjusting.
What's also nice is that when I switch off, the turbo is instantly quiet - gone is the whistling down noise.
Lastly, I've noticed the glow plug light goes off pretty instantly whereas with the old plugs it seemed to stay on alot longer. Appreciate, it is summer, but the old plugs were pretty coated in carbon crud so is that a sign that a long glow plug light indicated that they could need changing.
