Up right and plug holes/pipes with rags and keep indoors if possible and cover with a tarp, I would be tempted to spay "spay" grease over it if your are storing for a long time, you can jet this off when brining it back to life.
Agreed with Drifty on this. I would be tempted also to keep the flywheel and clutch kit on it as well if you know its a good clutch. Also if you are replacing the truck with another one the same then keeping the ancillaries attached as well would be advisable. You never know if your new vehicle is going to have a good alternator etc. A light dusting of WD40 is good enough to stop the block from drying out and going manky.
