what is it called
what is it called by scottp on Sun Jun 24, 2012 7:24 pm
Sorry to be thick but i snapped a bolt on the exhaust down pipe today where it joins near the turbo.
My question is this the bolt i need to remove is not 10mm and not 11mm and is not hex either it seems to be like a torx bit but on the outside instead.what is it called please so i can buy a socker as i need to remove the peice behind the exhaust to fix broken bolt.
scottp
Re: what is it called by Dannyboy on Sun Jun 24, 2012 7:29 pm
Could be a SPLINE bolt/stud mate :wink: .
Re: what is it called by scottp on Sun Jun 24, 2012 7:47 pm
Top man thanks. :thumbup:
scottp
Re: what is it called by Dannyboy on Sun Jun 24, 2012 7:53 pm
not a problem bud :wink:
Re: what is it called by snapper on Sun Jun 24, 2012 10:02 pm
Welly a slightly smaller socket onto it with a lump hammer, the thumping will shake the rust loose and it will (maybe) then come out.
Re: what is it called by scottp on Sun Jun 24, 2012 10:49 pm
thought about that but the way my luck has been i will probably make the roof fall off hitting it.
I have looked on ebay and i have these sockets but mine dont seem to fit on.
I have half inch drive and quite large stanley sockets,would a smaller drive 10mm socket be better??
scottp
Re: what is it called by Dannyboy on Sun Jun 24, 2012 10:55 pm
make sure the socket is the hex type n not the other multi point type!!
Re: what is it called by frontlee3 on Sun Jun 24, 2012 11:14 pm
i use a 8mm wall drive 3/8's drive on mine to be fair i use wall drive for all the bolts saves skin and blood :wink: and the dreaded rounding of heads but the 8mm fits em
must get it mucky
frontlee3
Vehicle Name: blue beast
Re: what is it called by scottp on Mon Jun 25, 2012 7:26 pm
ideal thanks but whats a wall drive
scottp
Re: what is it called by frontlee3 on Mon Jun 25, 2012 8:08 pm
wall drive is 6 sided socket same as the standard hex bolt head
must get it mucky
frontlee3
