What to clean pistons with
What to clean pistons with by N1ova on Tue Jun 12, 2012 10:10 pm
Hope this in the right place. I am currently rebuilding my astra engine. the pistons are carboned up what would be the easiest way to clean them up? Thanks for any help in advance cheers Adrian
N1ova
Vehicle Name: Blue flash
Re: What to clean pistons with by Rich on Wed Jun 13, 2012 6:27 pm
when i was into engine rebuilds i just used to leave things like that soak in diesel :D :D
Re: What to clean pistons with by RatCav on Wed Jun 13, 2012 7:33 pm
I used carb cleaner on some valves and piston heads. Just soaked them in the stuff and scraped the gack off with the end of a cable tie, then finished with a cloth. I summised that the cable tie would be soft enough to not damage the metal, but hard enough to scrape the carbon off. It took some time to get perfect but the result was a good one:
Re: What to clean pistons with by Gazeddy on Wed Jun 13, 2012 11:03 pm
for valves i put the in my drill and and use a coarse sand paper then poilsh them with green scourer. doing pistons i soak them and wipe off as much as poss then gently hit them with a scotch brite pad(red)
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: What to clean pistons with by RatCav on Thu Jun 14, 2012 8:11 am
Well pointed out Gazeddy ... I remember now I used a scotchbrite pad to polish them up with. I did my valves about 2 years ago and memory was a bit fuzzy.
Re: What to clean pistons with by N1ova on Thu Jun 14, 2012 10:57 am
Cheers guys
N1ova
