How strong is my roof?
How strong is my roof? by Kotch on Fri May 25, 2012 7:50 pm
Hi
I need to reach up to prune a small branch off of a tree next to my drive. It's only small and my loppers would do it but I can't get up that high. However it's right next to my Fronty. How strong is the roof of a Frontera B series? I notice it's got ribs along the length but I wonder if they are just cosmetic. If I were to stand on it would it support my weight (about 11 or 12 stone) without buckling? Alternatively what if I were to put planks on the roof to spread the load?
Any ideas?
Andy
It's an LWB B series, 2,2 diesel if that makes any difference.
"Every man and every woman is a star." Uncle Aleister.
Check out my book about my round England trip in my Fronty
https://unbound.com/books/in-satnav-we-trust/
Kotch
Modifications: It's a B series by the way. (There didn't seem to be an option of A or B on the list.)
All pretty standard now, including the rust. The wheels and tyres and spare wheel cover in the picture are gone now. The front badges had been removed when I bought it. I'm thinking of buying the letters for Canyonero to replace them.
Re: How strong is my roof? by Big Dav on Fri May 25, 2012 8:36 pm
Wouldn't be me relying on the sheet metal of the roof - those ribs, if pressed in the roof sheet, are probably there to cut out resonant vibration of the expanse of the roof. :wink:
Re: How strong is my roof? by Wilberforce on Fri May 25, 2012 8:47 pm
However the planks idea is a good one.
Spread them crosswise over the rails and I don't envisage a problem for the time needed to lop a couple of branches.
Admittedly I drive an A, but there's a roofrack on that which I've sat on quite frequently. By using that, or the rails/planks, any weight is being applies were it was intended to be, rather than the expanse of thin metal roof panel.
Re: How strong is my roof? by BoxCleva on Fri May 25, 2012 8:49 pm
My two daughters very often sat on my roof. In fact at the previous annual meet they were both on it along with one of Houndogs kids.
I'd put a scaff plank across the roof rails and stand on that if it were me.
Re: How strong is my roof? by gregster on Fri May 25, 2012 9:02 pm
or rachet strap a ladder to the tow bar/spare wheel.
Re: How strong is my roof? by Kotch on Fri May 25, 2012 9:19 pm
Okay, that's all good info, cheers.
I have got the roof rack bars in the shed so I might try putting them in a position so that I can stand a pallet across them.
Cheers again.
Kotch
Re: How strong is my roof? by tracey.geeson on Mon May 28, 2012 1:36 pm
i have stood on my frontys roof a few times to lop branches off trees and also to get to my stable roofs to paint them but usually put a plank across lol :D
tracey.geeson
Model: 3.2 V6 Sport Olympus 3dr
Vehicle Name: the beast
Modifications: limited edition swb 3.2v6 induction kit
Re: How strong is my roof? by AskDean on Mon May 28, 2012 1:42 pm
i regularly use mine as a platform but i would recommend stick something across it i weigh best part of 18 stone and it will take my weight but i ten to stick to the edges and then only to get on and off the ally plank i use as a step across the rails and just strap it on the ends to make it solid
AskDean
Skype Username: askdean
