V6...
V6... by woody13 on Tue May 15, 2012 9:35 pm
Ok,two weeks ago spent a grand on a 2.2 swb,got shafted with a blown head gasket(I might repair it)... :x
Just got a 3.2 V6 lwb auto,11mths mot,3mths tax, very cheap...What should I look out for...?
Woody... :twisted:
woody13
Vehicle Name: Anvil
Re: V6... by kees on Tue May 15, 2012 9:46 pm
A heavy foot :lol: . cannot help you otherwise, wish they did one in the A series.
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
Re: V6... by fogman on Tue May 15, 2012 10:02 pm
as kees has already said - fuel consumption, the v6 on average uses slightly more fuel than the 2.2 but being an auto that will be slightly more again compared to a manual,
but ofcourse you will be enjoying the extra power :wink: maybe the usual b series problems with the dials but other than that theyre pretty bomb proof, the only other thing id mention as with any other new car is - id want to change the cam belt if i didnt know for sure it had been changed recently.
Re: V6... by jimmybhoy on Tue May 15, 2012 11:32 pm
Even when mine has had some rough running issues (really bad a few weeks ago 02 sensors) it never failed to start or take me where i wanted to go, round trips of upto 130 miles. The full tank goes a bit like this :drink: if you hammer it, but i dont know how else to drive it :shh: . Absolutely bulletproof, askdean has done a few excellent write ups lately. Get the belts done, if there is no evidence of this in the history, may as well do the waterpump @ the same time.
jimmybhoy
Registration Year: 2004/04
Re: V6... by AskDean on Wed May 16, 2012 8:28 am
and the biggy if your doing a lot of miles in then bite the bullet and get it onto lpg as i know its cheap up our way around the 65p a litre mark last time i was up that way and it males it cheap as hell to run.
i went to coast this weekend and drvieing like a vicar i get to 74.2 miles when it hit the 2.8 gallon mark which is what i currently get for a tenner but then reverted back to a normal V6 holligan and got up to 180 miles before i filled the lpg tank off and it cost me under 35 to fill it off makeing it cheaper to run than a 1.8 focus.
but like the guys have said cam belt while our have it in bits lift off the carbs and do your thermosate if it takes longer than 5 miutes for heating to be like a volcano
just keep an eye in the oil as some v6 do drink it a bit but other than keep an eye on the speedo as the thing will haply give you 3 points without a second thought as it will happly cruise past the tonne if you have the chance of a track day to give it some stick lol
but welcome to club and i do have a fair few spares if you find you need anything give me a shout
AskDean
Skype Username: askdean
Re: V6... by Dave Tucker on Wed May 16, 2012 9:11 am
Keep an eye on the inlet manifold gaskets. If they blow the enging will run uneven and it will drink fuel even worse. I replaced mine a few months ago. Not to bad a job but the gaskets were £110. Hope yours is all good. :D
FRONTERAS ARE NOT FOR SCHOOL RUNS
Dave Tucker
Vehicle Name: Monty
Modifications: 3" Suspension Lift, Trooper +2 Coils, 2" Body Lift, Gas Shocks, Jap 16" Alloys with 32" Tyres, Modded Front Arches, Flipped BJ's, Lightened Flywheel, K & N Filter, S/S exhaust, Ken Lowe Electric Fan, HID Xenon Bulbs, Drilled & Grooved Brake Discs, Red Dot Pads, Lightened Fully Wax Oiled Body, Modified Front Diff Hangers and Rear Bump Stops, Removed Spare Wheel and Modified Rear Door and Bumper, Underbody Reversing LED's, 100w Hella Spots, DRL's, Sony Bluetooth.
Re: V6... by AskDean on Wed May 16, 2012 9:30 am
dave should of given me a shout among the spares i have in the shed are a set of intlet gaskets that have done less than 50miles as the cam seized on the engine after a rebuild so they where stripped out and removed an put tin the shed when i weighed the engine in after the replacement was fitted
AskDean
