rear half sharft removal tool
rear half sharft removal tool by fudge on Mon Apr 09, 2012 9:05 pm
i have been told there is a said tool for removable of the rear half sharfts, so i can get the rear diff out.
so is there one and who has it?
and i am sorry if this is in the wrong area
Re: rear half sharft removal tool by Gazeddy on Mon Apr 09, 2012 9:07 pm
if you pull your drum off youll find four bolts undo em shaft should slide out with bearing. only need bearinator if your replacing bearings
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: rear half sharft removal tool by fudge on Mon Apr 09, 2012 9:10 pm
well done that and they are not comming out
Re: rear half sharft removal tool by Trugga on Mon Apr 09, 2012 10:20 pm
The "Bearinator" (I believe there are two in existance) are custom made slide hammers - used for removing the rear half shafts.
Rear bearing removal here http://www.fronteraowners.co.uk/wiki/in ... l_bearings using the bearinator.
Re: rear half sharft removal tool by fudge on Mon Apr 09, 2012 10:44 pm
well then who has them?
and poss bring it to the annul meet
Re: rear half sharft removal tool by fronteramac on Tue Apr 10, 2012 10:19 pm
i used a bigger than normal car size hub puller when i did mine a real big heavy duty one which i boro,d from a mates garage, tryed normal car size one but arms were droppin off sliding the hammer part back and forth but soon as connected the much bigger one with in the second go the half shaft came out
fronteramac
2.8 td sport sold
Re: rear half sharft removal tool by 4x4 bobby on Wed Apr 11, 2012 7:22 pm
""I GOT IT"" :mrgreen: :mrgreen:
Re: rear half sharft removal tool by fudge on Wed Apr 11, 2012 9:43 pm
can i get it off you at the anual then
Re: rear half sharft removal tool by 4x4 bobby on Wed Apr 11, 2012 9:47 pm
Im not going fella but will give it to Manny as he's using my caravan!! Would that be acceptable? :mrgreen:
Re: rear half sharft removal tool by fudge on Wed Apr 11, 2012 9:51 pm
that will be great
now do you think i should replace the wheel bearings now
Re: rear half sharft removal tool by 4x4 bobby on Wed Apr 11, 2012 9:53 pm
How can you replace it now when iv'e got the bearinator here???????
Re: rear half sharft removal tool by fudge on Wed Apr 11, 2012 10:01 pm
i mean when i get the half sharfts out
but i would have to order the bearings now tho
Re: rear half sharft removal tool by 4x4 bobby on Thu Apr 12, 2012 3:07 pm
You can keep hold of the bearinator for as long as it takes bud!!!!
Re: rear half sharft removal tool by 4x4 bobby on Mon Apr 23, 2012 7:01 am
Fudge!! Bearinator in the caravan with Manny!
