Buying advice
Buying advice by Mike97 on Thu Feb 23, 2012 7:59 pm
Hi all. I'm going to replace my well worn freelander and I quite fancy a Frontera. I'm going to look at a 2003 2.2dti with 70,000 miles on it. I just wondered if there's any particular problems or weak points I should look out for. Any advice gratefully accepted. Thanks in advance.
Mike
Mike97
Re: Buying advice by meooo on Thu Feb 23, 2012 8:42 pm
Make sure the dash all works with and without the lights on
meooo
Cookie monster
Cookie monster
Vehicle Name: dead
Still sporting Salisbury mud
Gone to meet its maker :(
Skype Username: john.hird8
Re: Buying advice by rospicer on Thu Feb 23, 2012 10:46 pm
Probably a good idea to ask if the fuel pump (HP pump) has been changed or reconditioned. They are the weak point on the 2.2 diesels and on 2001 reg on-wards it will cost you in the region of 1200 to replace :shock: Look for rust in the rear door sill sections.
Also remember the frontera's 4WD is not permanent. There is a button to switch to 4 high but dont use it on grippy surfaces. The freelander is permanent (well if the prop is still fitted :lol: )
Overall the frontera is a much better 4x4, good luck with your search
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: Buying advice by BoxCleva on Thu Feb 23, 2012 11:13 pm
A recent pump change is a big bonus. But if it doesn't run right in any shape or form, walk away!
Re: Buying advice by Mike97 on Fri Feb 24, 2012 7:30 pm
Thanks for the replies. As regards the pump, are there any signs of imminent failure or is it just something that happens suddenly?
Mike97
Re: Buying advice by BoxCleva on Fri Feb 24, 2012 7:53 pm
Suddenly usually.
Re: Buying advice by fogman on Fri Feb 24, 2012 11:10 pm
i thought a new pump on the newer dti was nearer 2k to replace ?
Re: Buying advice by Drift on Fri Feb 24, 2012 11:11 pm
Foggy, they are around £600, but need fitting :wink:
Though some could be the top module faulty, that costs about £100 to sort.
Re: Buying advice by BoxCleva on Sat Feb 25, 2012 8:51 am
You won't get a later plate Dti pump for £600 :|
Re: Buying advice by fogman on Sat Feb 25, 2012 9:04 am
yeah vx supply only i believe :?
Re: Buying advice by Mike97 on Sat Feb 25, 2012 2:51 pm
Didn't buy it. Obvious signs of accident damage on nearside and the gearbox was very "notchy". Also the clutch juddered and didn't bite till near the top of the pedal travel. Thanks for the replies. I'll keep looking!
Mike97
Re: Buying advice by BoxCleva on Sat Feb 25, 2012 5:50 pm
Clutch pedal at the top is normal, judder is not. Good decision to walk away.
Users browsing this forum: Google [Bot] and 31 guests
