Frontera Technical Support • View topic - Impressive But..............
Impressive But.............. by colley on Thu Feb 16, 2012 9:44 am
shows why the front diff is a weak point on the frontera :lol: been there and done that :lol: :lol:
http://www.youtube.com/watch?v=XlRI4n4pTDU&feature=related
Re: Impressive But.............. by dt1968 on Thu Feb 16, 2012 11:34 am
watched this last night...pretty obvious something was gonna give up... no surprise its the front diff !!
more impressive would of been to see him climb gently up and over the rock using the torque from the engine! instead of flat out max revs and lots of wheel spin,, resulting in lots of noise ,zero control of the fronty at the top, and wreckin a diff. :D
2.8tdi lwb.... 2"lift.. 31.10 15s snorkel cb
dt1968
Modifications: 2" spring lift. .cb .torsion wind up. snorkel .2"bodylift
31.10.5 15s
Re: Impressive But.............. by gregster on Thu Feb 16, 2012 11:51 am
Wonder why he didnt air down, would have given a load more grip and stopped it bouncing around so much :? :? :?
Re: Impressive But.............. by Drift on Thu Feb 16, 2012 1:10 pm
Ermmm its not a fronty, its an Mu so it has trooper diffs :wink: lol
Re: Impressive But.............. by colley on Thu Feb 16, 2012 2:22 pm
That would explain why he got to the top of hill before the diff broke then, as the fronty one would have broke on the first attempt :lol: I am starting to sound like a landy owner :lol: :lol:
That said I have never seen any physical evidence to say the trooper diffs are stronger than the fronty ones :|
Re: Impressive But.............. by Drift on Thu Feb 16, 2012 3:57 pm
You are h,ahaha , that said the diffs are still better than lr halfshafts :thumbup:
Re: Impressive But.............. by furball on Thu Feb 16, 2012 4:56 pm
At 3:05 his mate asks "have you got your front locker in?", so they ain't standard diffs. Plus if you look right at the end it looks to me like he still has drive at the front :roll:
furball
Re: Impressive But.............. by colley on Thu Feb 16, 2012 6:21 pm
Re: Impressive But.............. by RatCav on Thu Feb 16, 2012 7:42 pm
They also say towards the end that his CV has gone. If it was locked at the front then the CV's are the next thing to go when torturing a vehicle like that.
Re: Impressive But.............. by Drift on Thu Feb 16, 2012 8:03 pm
Correct, its something I am surprised we dont see more CV problems, the guys on PlanetIsuzoo seem to suffer bust CV's a lot :?
Re: Impressive But.............. by RatCav on Thu Feb 16, 2012 8:13 pm
That's because they all have lockers over there Drifty ;)
That vid above as well indicates bust CV as it was clattering when the wheels are turned, but went quiet when straight.
Re: Impressive But.............. by igotababyfrontera on Thu Feb 16, 2012 8:18 pm
:shock: breaking something or not, I'm impressed :!:
I wouldn't have tried it though :oops:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: Impressive But.............. by gregster on Fri Feb 17, 2012 12:30 am
LWL suffered CV failures with the welded front diff...but a when I welded the rear as well it sorted that, the CV's were fine then! 8) 8) 8)
I just blew up the powersteering then!! :lol: :lol: :lol:
Re: Impressive But.............. by RatCav on Fri Feb 17, 2012 1:12 am
Bit like what's happened to BGL then Greg ;)
Users browsing this forum: Google [Bot] and 34 guests
