What meoo said, plus go give it a spin around an empty snow covered car park to get used to handling the truck in the snow. Dont forget it will handle differently when in 4wd. Oh and don't forget.....
Just because you have a 4x4, and have stuck it in 4x4 mode it DOES NOT mean that it won't slip n slide like a ducks arrse on ice... so don't go driving like a demented teenager or you will end up in a ditch!
