first fronty 2.8
first fronty 2.8 by SIVY28 on Thu Jan 26, 2012 2:04 pm
hi all im a newbee and looking at my first frontera 2.8 today its a 1996 service history and 130000 miles cambelt done 10000 ago im used to checkingcars out eg gears clutch brakes etc but is there anything specific i should watch for on the fronty
any help appreciated
im in shropshire hoping to greenlane
SIVY28
Vehicle Name: CLARENCE
Modifications: Waiting to lift it 2 inch
Re: first fronty 2.8 by dt1968 on Thu Jan 26, 2012 2:29 pm
hiya ,, and welcome.. where abouts in shropshire are u??
2.8tdi lwb.... 2"lift.. 31.10 15s snorkel cb
dt1968
Modifications: 2" spring lift. .cb .torsion wind up. snorkel .2"bodylift
31.10.5 15s
Re: first fronty 2.8 by SIVY28 on Thu Jan 26, 2012 2:47 pm
hi between ludowand bridgnorth hoping for people to link up with once i get sorted ,
SIVY28
Re: first fronty 2.8 by Drift on Thu Jan 26, 2012 6:51 pm
Check the rear diff for leaks, fixable and a good bargaining point, just make sure its not to smoky :wink:
Re: first fronty 2.8 by snapper on Thu Jan 26, 2012 7:32 pm
Try and find out how often the engine oil has been changed (mileage) your looking for around 3 to 4.5k depending on the use and if the U/J joints have been greased. Check to see if the heater works or if it gets confused and operates like a fridge... most do. Check door handles, assuming it's a lwb the rear door handles have a nasty habit of breaking if they arent kept clean and lubricated. Electric Mirrors, the switch is at best vague... Oh and ask them if it's ever been run on tesco veg oil or ex chippy oil, if it has then use that as a bargaining point because it can bung everything up.
Don't forget, when you get it, do a full oil and filter service on it.
Re: first fronty 2.8 by SIVY28 on Thu Jan 26, 2012 11:42 pm
well damn it the clutch was slipping and the temp gauge never moved (thermostat ?) so heaters cold but how much roughly to fixaclutch on these or is it not worth bothering ?
SIVY28
Re: first fronty 2.8 by Drift on Thu Jan 26, 2012 11:51 pm
A 2.8 takes about half an hour to even get the temp needle moving :lol: well 20 minutes mine takes :wink:
A clutch at a garage will be about £150 for the kit (£120ish if you buy the kit yourself) and add about 4 hours labour at what ever rate the garage charge.
Re: first fronty 2.8 by snapper on Fri Jan 27, 2012 9:59 pm
A dead clutch? worth bothering with? Nah, tis far far too hard mate, I'd get rid if I was you.... :roll: Tell ya what, I'll give ya 50 quid for it, get it off yer drive an all that :wink:
:2.8 owner 1: :lol lol:
