be careful when buying cheaper electrical cables from ebay,there are a lot of cheaper imports from china etc that has got sub standard insulation or the wire is not rated to the correct current ie 20 amp cable that really can only take 15 amps,durite is a well known supplier though.
Modifications: Largely Standard at the minute. & Standard 2010 Renault Megane 1.5 Turbo Deisel for the daily commute. Downside, no 4x4, up side around 700 miles to a tank of Diesel....... & Tuned Volvo C70 for Sunny Days and Roof Down Fun & Modified BMW R1200RT for Touring, commuting and general two wheeled fun.
Looks like I'm in trouble with the Mrs's again... She asked me what I'd most like to do to her body... Apparently "Identify it" is not the correct answer!
Modifications: Drive a 2.2dti olympus, 2.8 lwb and 2.0i sport. Breaking... 2.4i and 2.3td 2.0i C20ne and x20se x 4 2.8tdi x2 2.2i A 2.2i B LWB x3 x22dth B dti lwb x3 y22dth B dti lwb x5 Call Fronty4x4spares on 01622 739908. Same day dispatch, next day delivery on 95% of items.
I cannot fault Vehicle Wiring Products. Have used them countless times. Very quick, cheap, and good quality. We use them at work as a preferred supplier as well.
Can you not just use any old facelift switch Rob, its gotta have a relay anyway, so would only be switching low current at the switch...could get a nice illuminated one too Shoot boxcleva a pm, he's breaking a 2.5...
