Frontera Technical Support • View topic - been to look at the new frontera
been to look at the new frontera by richardshall on Sat Jan 07, 2012 9:53 pm
Hi All,
been to have a look at the new car today and take it for a test drive,
Its a 2.2 tdi y reg 2001, drives lovely and in good condition. The only thing is the eml flicks on for a bit when in traffic, any ideas what this could be ???
Also its got a bracket on the back for a towbar but theres no towbar there, any ideas how much for one or has anyone got one for sale.
Thanks
Rich :D
richardshall
Modifications: TTI CB RADIO
1.5M SPRINGER AERIAL
.. and more to follow soon ..
ROOF LIGHTS/ AIR HORN TO COME SOON :-)
Skype Username: richard.hall.83
Re: been to look at the new frontera by BoxCleva on Sat Jan 07, 2012 9:58 pm
You've bought the car, now buy the code reader :wink: viewtopic.php?f=27&t=46352&p=500551&hilit=code+reader#p500551
Re: been to look at the new frontera by snapper on Sat Jan 07, 2012 10:01 pm
Define bracket for towbar...
Is the tow ball one of the swan neck plug in removable types? or a simple bolt on jobby. Either way ebay is your friend unless some one is breaking one on here.
Re: been to look at the new frontera by richardshall on Sat Jan 07, 2012 10:06 pm
not sure if im being honest, only had a quick look i was concerntrating on the other parts of the car mainly. it had two identical pieces of metal coming out from under the bumper about 2 inches apart but thats all i can remember lol.
Reason: removed quote as poster quoted is only above
richardshall
Re: been to look at the new frontera by Dannyboy on Sat Jan 07, 2012 10:18 pm
sounds like a bolt in neck mate, its a piece of 40mm solid box with 2 12mm corosponding holes in it.
Re: been to look at the new frontera by richardshall on Sat Jan 07, 2012 10:36 pm
Thats great thanks, any ideas on a rough price or where to get one from. ??
richardshall
Re: been to look at the new frontera by Dannyboy on Sat Jan 07, 2012 10:41 pm
allvox mite have one, or a scrapper near you, or a new one, you could try pct automotive, i used to design,make n fit them when i worked there. :thumbup:
Re: been to look at the new frontera by richardshall on Sat Jan 07, 2012 11:54 pm
Nice one thanks mate :D
richardshall
Re: been to look at the new frontera by Rich on Sun Jan 08, 2012 8:23 pm
if its a swan neck tow bar have a look under the rear seats for the other bits Rich :D
Re: been to look at the new frontera by bushwacker on Sun Jan 08, 2012 9:21 pm
hi ya :) what bits would they be :?: i have a 2.4 with a swan neck towbar, under the rear seat i saw a few extra bits apart from the jack and handle, what they for then :?:
bushwacker
Vehicle Name: ?
Re: been to look at the new frontera by richardshall on Sun Jan 08, 2012 9:54 pm
richardshall
Re: been to look at the new frontera by richardshall on Mon Jan 09, 2012 8:44 pm
Looks like im going to let this one go. He has decided to virtually double the cash that he wants on top of my car lol
Looking at another one.. Its a W reg but the airbag light is on and the speedo isnt working. It has done 150000 miles and its a 2.2dti, it seems a bit high but opinions would be appreciated.
Thanks
Rich :D
richardshall
Re: been to look at the new frontera by Dannyboy on Mon Jan 09, 2012 8:46 pm
how much is your budget n wot are you after ideally pal??
Re: been to look at the new frontera by richardshall on Mon Jan 09, 2012 8:50 pm
the budget depends at the moment really, ive got a 2ltr swb niagra sport. so i would prefer to p/x , i would like a 2.2tdi series b but it depends on the price really
richardshall
Re: been to look at the new frontera by rospicer on Mon Jan 09, 2012 9:00 pm
150K on the clock and the speedo isn't working :shock: chances are good the mileage is quite a bit higher, as the odo doesn't work without the speedo
Try get the V5C ref number and the reg number and do a check on the VOSA website to check the last 5 years of MOT and what the mileage was each year :wink:
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: been to look at the new frontera by Dannyboy on Mon Jan 09, 2012 9:16 pm
id hang on a couple of mnths if i was you mate as prices are startin to come down again.
Re: been to look at the new frontera by richardshall on Mon Jan 09, 2012 10:45 pm
richardshall
Re: been to look at the new frontera by Dannyboy on Mon Jan 09, 2012 10:49 pm
im the opposite mate, i got the bus n im moving into a sport :lol:
Re: been to look at the new frontera by MrTom on Tue Jan 10, 2012 12:39 am
You got a sport yet Danny ?
Rich you dead set on a 2.2tdi?
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: been to look at the new frontera by richardshall on Tue Jan 10, 2012 1:45 am
hi Tom, im not dead set on one but i need a lwb and preferably a diesel. i like the series 2, but it depends on funds.
richardshall
