Frontera Technical Support • View topic - he said it's had it's intercooler flushed for the mot...
what's that supposed to mean?? good or bad?
and the chassis' been hammerited so have the leafsprings. same question good or bad?
this is a chap i've just spoken to about a 2.3 for sale. '94.
any opinions as i'm new to fronti land !!
:crazy:
concordeski
having the intercooler flushed for its mot could indicate that it was smoking alot on the smoke test,maybe excessive oil being burnt and depositing in the intercooler,the chassis being hammerited is a good thing as long as its not covering up loads of dodgy repairs or areas of rot on the chassis.have a good tap round underneath it to check its condition and see how much it smokes when its fully warmed up and revving the engine.
crackpotterpig
Modifications: bog standard!-now sold-frontera less
ok thanks crackerpot, all good advice i'm sure and will execute promise, but... i must decide if i'm buying it without seeing it in th flesh as i live in normandy and the cars in england...hmmm.. dilemme ! lol.
i'm not a total "idiot" in "mechanics" but long shot off expert or even averted amateur :D !
as for the hammerite yeh it does what it says on the tin sure, also does a good job of bodging :shh: lol. just don't want to get caught out, things are tight... need car and need it to work, correctly.
for the intercooler system i know nothing !!
concordeski
he did say failed mot, then had it all flushed and it went straight thru....
burning oil... valves? rings?
concordeski
The 2.3 tends to be a very smoky engine at the best of times, personally with your budget I would wait for slightly newer Frontera comes up considering the logistics.
Frenchfarmer
It works!!!!
hmm... thanks chaps.. but.........
drift, what do you call "slightly" newer?
missed a few what i think look reasonable lasses on fleabay and gumtree last few days, starting to give up!!
et pas de vehicule en ce moment, dung!! lol.
(can i swear in french?)
concordeski
no i can't lol...!
concordeski
hifrench farmer, yeh i know boncoin. and angloinfo, but 1, high price, and 2, not often registered in france if british to begin with.
and i have a very small budget...
concordeski
oil in the intercooler is probably turbo seals starting to fail,saying that it could be a really good bargain is there any history with it? even if the turbo is knackered its not the end of the world.
crackpotterpig
I was thinking more the later A series diesels on coil suspension :wink:
from late '95 onwards coils weren"t they drift?
and crackpotterpig, if it's the seal how much does that cost to fix, doable myself? no no real history, chap has modified it himself and done the servicing himself. been jacked up and stuff, had new starter, glowplugs this year. :oh yer:
concordeski
no advisories on the mot after this "flush" job.
concordeski
All post 95 are on coils, the leafers are 2.3/2.4/20l before 95 :wink:
Turbo seals would mean a new turbo they are not really a DIY fix :(
hi guys, what about a 99 2.2dti? engine management light comes on time to time apparently vacum leak...
could this be true? cheap fix or ignore?
or another barge pole job?
thanks for everybodies advice, and happy new year to you all!
concordeski
It could be a simple fix but, I can never understand seller selling a car with an apparent "easy or cheap" fix, why dont they fix it then?
Always gets me that one :wink:
It may well be easy but know one can tell unless the codes are read or its looked at :(
hmmm...
concordeski
Stick with it fella, there will be one out there for you and the more time you have the better your investment is likely to be :thumbup:
so why not the one that had it's cooler flushed? is it really that bad?
or how easy are fuel lines to replace and whats a steering idler?
concordeski
