Halfrauds nuts n bolts? Good enough to chuck at the cat on the veg patch but for anything remotely more serious, personally I wouldn’t touch em.
Source the nuts n bolts yourself from the scrappies, spanner in hand, that way they will fit and in 99% of the case will be of the right tensile strength. Failing that a proper fixings supplier or engineering supplier that doesn’t look at you like you have two heads and are talking in riddles when asked about tensile strength, thread pitch and if drilling/tapping the hole the size of drill required for the tap, like the 'expert' did at my local halfrauds once!
snapper on Sun Nov 20, 2011 9:00 pm, edited 1 time in total.
