Frontera A 2.0 petrol
Frontera A 2.0 petrol by gazza1591 on Sun Nov 13, 2011 3:29 pm
Hi all
Looking to get the above frontera going to look at it tomorrow it has full history and 80k what do I need to look out for on this frontera ? I'm looking to get it and do a few mods and use it for some green laneing and off road days and some general day to day driviving in bad weather. Also it's on an s plate does it have switchable 4x4 on it like the frontera B does ?
Thanks
gazza1591
Vehicle Name: the tank
Modifications: none as yet but plenty to come
Re: Frontera A 2.0 petrol by Drift on Sun Nov 13, 2011 4:07 pm
Here yo go Gaz, some good info here :wink:
viewtopic.php?f=41&t=9301
The 20l doesnt have the vac shift system, good old fashion mechanical system.
Re: Frontera A 2.0 petrol by gazza1591 on Sun Nov 13, 2011 4:16 pm
Thanks drift
Is there an easy way to check the 4 wheel drive on the above frontera then ?
gazza1591
Re: Frontera A 2.0 petrol by Drift on Sun Nov 13, 2011 4:44 pm
Its best if you find some soft or loose ground to try it on, you can however use 4wd on tarmac in a straight line, engage 4wd and and keep it straight, also see if the light on the dash lights up , check there is a front prop-shaft attached as if there is a problem its been know for the prop to be removed to disguise the fact.
But on this system there is very little to go wrong that can not be easily fixed.
This may help
Also have a good look through here
Grab a beer or a cuppa and send the kids out to play :lol:
Re: Frontera A 2.0 petrol by gazza1591 on Sun Nov 13, 2011 4:52 pm
Thanks for that will check it out when I go to view it Tuesday
gazza1591
Re: Frontera A 2.0 petrol by john boy on Sun Nov 13, 2011 5:47 pm
Check the outter sills for rot, fuel lines and brake pipes to the rear by the o/s/r wheel arch area, where the rear roll hoop mounts on the wheel arches oh and around the clutch master cylnder on the bulk head for splits. Other than that just look at the general condition. Mines on an "R" plate had some and had some right stick thrown at it was in very good nick and give £450 for it had a few months tax and short mot. Just done 81000m got do the head on it now as thats give up the ghost but got to say this is my 2nd "A" and love it!
Re: Frontera A 2.0 petrol by gazza1591 on Sun Nov 13, 2011 9:59 pm
Thanks for the info will check it all when I go to view it
gazza1591
Re: Frontera A 2.0 petrol by Big Dav on Sun Nov 13, 2011 10:17 pm
The scuttle tray below the front windscreen can rust through, pay attention to the bodywork around the front windscreen for corrosion bubbles too and also the roof area between the doors just in case mega sized bubbles are forming.
Good luck & hope all goes well.
Re: Frontera A 2.0 petrol by Retro Pedro on Sun Nov 13, 2011 10:23 pm
Have a look at the rear diff cover plate for signs of leakage. After time they become porous and show signs of leaking. Replacement's have been hard to source of late, so if the signs are there, listen for rear axle diff whine, it might have been run with low level diff fluid. If the diff sounds OK and the plate is leaking, it's not the end of world, because Greg on here as started selling repaired covers on an exchange basis.
