I bought myself an old Sherry 50litre air compressor a couple of years back on fleabay - saw it start up and work OK from cold start up so bought it. Until tonight, it's been stored in my shed waiting to be used in anger. Got it all rigged up with the tyre pressure gizzmo, plugged it in and nothing. I know the electric socket that it was plugged into is OK and I've changed the 13amp fuse in the plug. Took the cover off the switch gear and all the wiring looks OK.
So before, I start taking bits apart, is there normally a component somewhere that would give issues if not used for a long time. Mate down the road said try the switch gear. I've got a multi-meter to put across a few terminals to see if it's getting electric where needed but other than that, I really haven't got a glue.
Guess it's a matter of putting the meter reader on volts and seeing if there is any current going through. I'm not going to spend money on it because it only cost £20 to start with, but before I throw it in the skip, thought I might have a little dabble to see if I can get it working again.
