Frontera Technical Support • View topic - Does anyone know the history of this fronty _west brom area
Ive seen this car for sale and just wondered if it used to belong to anyone on here or if anyone has seen it.
Its on a private plate at the moment Reg: CKZ 6556.
Thanks
Rich :D
richardshall
Modifications: TTI CB RADIO
1.5M SPRINGER AERIAL
.. and more to follow soon ..
ROOF LIGHTS/ AIR HORN TO COME SOON :-)
Skype Username: richard.hall.83
A pic might help bud
richardshall
Ahh it's a B series. No mate, I certainly don't remember it . Is it Diesel ?
richardshall
If the abs light is on then you will probably find that it is one of the seatbelt pre-tensioner connectors under the driver/passenger seats (yellow socket) its common on many cars and very common on fronty B's. With ignition off spray switch cleaner into the sockets and waggle them about (the sockets are spring loaded) do one side then turn ignition back on to see which is playing up. I finally ended up cutting the wires and soldering them up :wink:
Hope this helps :D
If at first you don't succeed BUY A FRONTY
Image Image
meezermum
Vehicle Name: Fablon Fronty
Modifications: Trooper springs, Pro-Comp shocks, 9mm ally bash plate, 2" box section and tube rock sliders, AirFlow snorkel, 3" torsion wind up, Kumho 265 75 r16 kl71 tyres, in dash CB, new clocks cos Fronty B,s are notorious for faulty ones lol an engine remap! 13000lb winch, 7" touch screen DVD, bluetooth, satnav stereo with rear camera and a volt meter!! Fitted heated leather seats and door cards. Tinted side and rear windows and lastly a mini fridge and two cup holders
richardshall
Any time bud :D
Image Image
meezermum
richardshall
town I get around 22mpg, combined i get around 38 to 40 mpg's. The 2.2 petrol uses more and the v6 more still but you get about the same cost per gallon if you get a v6 with lpg. I have had my Fronty for a couple of years now and its used daily for my work and for green laning too, she performs brilliantly in all weathers, on and off road. The best car I have ever had! :wink:
Image Image
meezermum
bobbinsjob is breaking his b dti so might be worth pming him for any potential parts needed :wink:
richardshall
Going off the subject but does anyone know the going price for a 2.5 td thats done about 150,000 in fair condition on a P plate ??
richardshall
Rich, cannot remember where from but the car looks familiar - especially as it was badged up as an Opel.
ok thanks, it looks like a tidy motor/ the seller is asking for my car (2.0ltr niagra sport 1997 done 87600 miles + 450 cash) the only thing is the frontera in the pic above has done 138000 miles which seems alot for an s reg even if it is a diesel. Is this normal for these fronteras or is it high, any input appreciated.
Thanks
Rich :D
richardshall
how i look at it, if a car does 10k per year on average then 138 is a bit above, but if it has good service history, runs ok (no smoke!), all fluids are where there supposed to be (not dripping or leaking) then engine wise that mileage isn't anything to worry about. What i would do is give it a dam good test drive to include
full lock steering (listen and feel for any knocking, whining or grating) acceleration and breaking hard (look out for pulling to left or right) make sure that the 4h and 4low work correctly, while you are out try looking at the sockets i told you about to see if it solves the abs problem :wink: if it does then make sure you put the fault back :wink: look in the air filter box for signs of oil/soot, look at the vac pipes to see if they have been replaced at any time, test all the electrics especially the rear wiper!! another good indicator for how the mileage has been put on is stone chips and steering wheel wear (lots of chips and not much wear to s/w normally indicates motorway mileage!). How many owners has it had? this is also a good indication on its reliability
Some of the things i have said sound obvious but most people forget about these things when looking at a new motor, i myself have done it and bought a pile of c?&p before because it was shiny and looked good :oh yer: especially if you buy off a dealer!! they are good at hiding faults with spit and polish :twisted:
Hope this helps
Cheers Tony
Image Image
meezermum
Same car , but now for sale in Wallasey. Makes you wonder why he's getting rid after a month. No mention of an ABS light, and the description lists it as a 99' reg not a 98.
http://www.ebay.co.uk/itm/1999-OPEL-SIL ... 720wt_1185
deepdiver
Vehicle Name: Dirk Diggler
Modifications: Colour Coded Bump bars.
front spot lights
side steps
Blue neon dash/footwell light conversion
tinted windows
Boost and oil pressure gauge installed on dash.
that reg is from ulster. worth a look at pnc
fynn
Registration Year: 1994/M
Vehicle Name: stumpy
Yep! that is a Northern Ireland Plate around late 1998 early 1999, and if the ABS light is on it is more than likely a wheel sensor (expensive repair). If the air bag light is on then the place to look is under the front seats at the yellow plugs (Cheaper Repair)
To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be.
chrispynuts
Vehicle Name: Silver Fella
Modifications: 2"lift with Isuzu Springs @ rear + koni shockers
255X70 General tyres
270,000 miles and on third fuel pump
replaced all fuel lines and all Vacuum pipes
replaced fog lights with 5" headlights (gives me main & dip)
fitted soft nudge bar and spotlights
stage 1 engine remap
Region: Northern Ireland
Users browsing this forum: No registered users and 95 guests
