Frontera Technical Support • View topic - What do I look for?
What do I look for?
What do I look for? by Jamie Read on Sat Oct 08, 2011 8:59 pm
I`m going to look at a V plate, 2.2 Dti tomorrow and I`m wondering what do I need to look out for and where?
Apparently the speedo has stopped working and the alarm light flashes until the key is turned(?)
Any help would be great!
Thanks
Jamie Read
Re: What do I look for? by gregster on Sat Oct 08, 2011 9:10 pm
History mate....lots of history...preferably including a new injector pump recentlyish... :wink:
Re: What do I look for? by Jamie Read on Sat Oct 08, 2011 9:19 pm
Hmmm... well the guy has only had it for a month, bought it for the Mrs, who thinks its too big( oooo- errr) and wants a smaller motor.
Jamie Read
Re: What do I look for? by Frenchfarmer on Sat Oct 08, 2011 9:41 pm
Frenchfarmer
It works!!!!
Re: What do I look for? by BoxCleva on Sat Oct 08, 2011 9:44 pm
Common problems:
Vac pipes - replace them all if they haven't already been done - £15 'ish, dead easy job viewtopic.php?f=6&t=39514
Crank sensor - £40
MAF - second hand £45 ish
The engines themselves are pretty robust to be honest. The weak link is the injection pump as previously mentioned. Many have been replaced in their lifetime. Don't ever run it out of diesel or attempt to start it after a filter change without properly bleeding the system.
In general they are a good bus. A read through the 2.2 section should throw light on many of the issues.
EDIT: Another essential bit of kit is a code reader. The ELM 327 works well with the Dti and and at under 20 notes is good value.
Re: What do I look for? by gregster on Sat Oct 08, 2011 9:47 pm
Re: What do I look for? by Jamie Read on Sat Oct 08, 2011 9:49 pm
Awww... don`t say that French/Gregster! I`m really hoping it`s a good `un as I`ve sort of got my heart set on one now!
It does look fairly tidy from the pics, I know you need to look underneath etc, and I will beat him down from his £900 pricetag.
What are the "expensive problems" you usually find then?
Jamie Read
Re: What do I look for? by BoxCleva on Sat Oct 08, 2011 9:51 pm
Re: What do I look for? by gregster on Sat Oct 08, 2011 9:52 pm
They get some rust up behind the rear bumpers, but the fuel pump has got to be the main concern on one of these...
In fairness if the pump is iffy, and you manage to knock him down a bit on the price, you can budget for spending as much fixing the pump as you did buying the car...they aint cheap I am afraid.
Re: What do I look for? by Jamie Read on Sat Oct 08, 2011 9:54 pm
Getting a little concerned now :cry:
Jamie Read
Re: What do I look for? by Jamie Read on Sat Oct 08, 2011 9:58 pm
Tell tale signs for a failing pump?
Jamie Read
Re: What do I look for? by BoxCleva on Sat Oct 08, 2011 9:59 pm
Jamie, I've seen dti's sell for scrap money on Ebay because ignorant owners assumed their pump was fubared, only for the new owner to fit new leak off pipes for less than £3. (One very recently :roll: )
Look at it , give it the full check over and post any concerns back here once you've looked at it.
Re: What do I look for? by BoxCleva on Sat Oct 08, 2011 10:00 pm
Re: What do I look for? by Jamie Read on Sat Oct 08, 2011 10:07 pm
Thanks BoxCleva, I will be giving it a good look over, plus I`m taking a mate who`s mech savvy so will have two pairs of eyes going over it.
Will I be able to notice problems with the pump, other than it conking out due to fuel starvation, such as noisy pump/ trouble starting etc?
Jamie Read
Re: What do I look for? by BoxCleva on Sat Oct 08, 2011 10:11 pm
No noises, in general it just won't run.
Re: What do I look for? by Jamie Read on Sat Oct 08, 2011 10:20 pm
Well I know it runs, so thats a start!
Jamie Read
Re: What do I look for? by BoxCleva on Sat Oct 08, 2011 10:23 pm
Make sure you give it a thorough test drive and you'll be fine. Make sure you can feel the turbo coming in (around 2000 rpm).
I think we may have inadvertently frightened you off, but go into it with open eyes and you'll be fine.
Re: What do I look for? by Jamie Read on Sat Oct 08, 2011 10:27 pm
It`s not that you`ve frightened me off, just made sure I know what to look for.
I got stung in the past with another disco, which siezed after 6 weeks, so have become more wary naturally. I really do have my fingers crossed for this one.
Jamie Read
Re: What do I look for? by Jamie Read on Mon Oct 10, 2011 8:54 pm
Well, went to look at it today and it turned out to be a shed!
No brakes- none at all!
64000 miles?? mot history showed 164000 in 2008????
dials only worked when lights were on
perished bushes
That was enough for me to walk away, even after the guy lowered his price to £700 :cry:
Jamie Read
