Astra mk3 1.4 8v coolant?
Astra mk3 1.4 8v coolant? by N1ova on Thu Sep 29, 2011 9:49 am
Hi im just about to change the coolant in my m reg 1.4 8 valve astra. What colour antifreeze should i buy for it? I have always used red in the fronty. Also anyone got any ideas as to how much coolant it holds? Cheers Adrian :D
N1ova
Vehicle Name: Blue flash
Re: Astra mk3 1.4 8v coolant? by Drift on Thu Sep 29, 2011 10:01 am
Not sure on the amount but I just used the blue stuff you get in any garage or shop when I had one.
Re: Astra mk3 1.4 8v coolant? by RatCav on Thu Sep 29, 2011 10:03 am
The older 8v engines use the blue stuff. Just change it annually.
Re: Astra mk3 1.4 8v coolant? by Dave_RAYNET on Thu Sep 29, 2011 11:25 am
from memory, from empty when i did the head gasket on mine it was about 5 litres. I've always used the red stuff. Last december the blue stuff i had in my astra froze solid. :shock: Luckily it didn't take any hoses.
Dave_RAYNET
Modifications: not yet
Skype Username: dave_m0yaa
Re: Astra mk3 1.4 8v coolant? by RatCav on Thu Sep 29, 2011 12:09 pm
Blue stuff degrades after a year or so and loses its quality hence changing it annually. Also a lot of people suffered from frozen engines as the mixtures were incorrect. A lot of garages just chuck some in to change the colour and that cannot cope with the -18 degrees we had temperature wise. That sort of temperature you need a 50/50 mix or more to prevent freezing.
Re: Astra mk3 1.4 8v coolant? by N1ova on Thu Sep 29, 2011 12:48 pm
So if i use 4 litres of blue i should be ok? I might buy the red from some comments on here. Confused now :(
N1ova
Re: Astra mk3 1.4 8v coolant? by Drift on Thu Sep 29, 2011 12:56 pm
Seriously the different colours do not matter for that engine, just get the mix correct :wink:
Re: Astra mk3 1.4 8v coolant? by N1ova on Thu Sep 29, 2011 1:08 pm
Cheers Drift, Can i put 4 litres blue in?then 1 litre water?
N1ova
Re: Astra mk3 1.4 8v coolant? by Drift on Thu Sep 29, 2011 1:15 pm
I would use two litres of water at least :wink:
Re: Astra mk3 1.4 8v coolant? by fogman on Thu Sep 29, 2011 1:32 pm
50/50 is normally the ratio warm in the winter & cooler in the summer :wink:
Re: Astra mk3 1.4 8v coolant? by RatCav on Thu Sep 29, 2011 2:10 pm
The mixture levels for ambient temperatures are usually printed on the blue stuff bottles ;)
Re: Astra mk3 1.4 8v coolant? by MrTom on Thu Sep 29, 2011 9:35 pm
Just out of interest why can't you just put full concentrate in? Surley that would ensure no engine freeze???
MrTom
Model: 2.0i Sport Niagra 3dr
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
Insa Turbo special tracks
2" suspension Lift
Spare wheel carrier removed
Rough country Shocks
Roof Rack
4 X 55 Watt roof lights
Tow Bar
Fan over ride switch
Bucket seats
3-point Sparco Harnesses
Rear seats removed
Manual locking Hubs
Rear welded recovery point
Winch bumper
Winch
Re: Astra mk3 1.4 8v coolant? by N1ova on Fri Sep 30, 2011 8:58 pm
That's what i was thinking. Would 100% mix damage it?
N1ova
Re: Astra mk3 1.4 8v coolant? by Drift on Fri Sep 30, 2011 9:05 pm
Im not 100% sure but I think the water and anti freeze have a chemical reaction to produce the best cooling and antifreezing plus lubricating also anti rust qualities.
A lot is going on with the mix but I am no chemist.
Re: Astra mk3 1.4 8v coolant? by john boy on Sat Oct 01, 2011 7:05 am
If you use 100% antifrezze there is a chance it will frezze i know it sounds crazy but it's do with the chemical reaction when the water added. Also i know there is a difference inthe vw blue g11 and pink g12 as when i was vw if you mixed the it turned to a glopp and we had to flush the system with chemicals.
Re: Astra mk3 1.4 8v coolant? by MrTom on Sat Oct 01, 2011 5:10 pm
Fair do's mate. It dosn't make sense to me but you sound like you know what your on about. :wink:
MrTom
Vehicle Name: Felix
K&N Filter
Tinted windows
Under sealed
16" Modular rims
2" suspension Lift
Roof Rack
Tow Bar
Bucket seats
Rear seats removed
Manual locking Hubs
Winch bumper
Winch
