Sorry to dilute pure Fronty with French stuff, but I'm desperate! Got a T reg Renault Laguna, petrol, estate, 1.6. About a year ago it had a problem where if I braked and indicated at the same time, the fuses popped - actually think it was just the brake light fuse that kept going, but this also stopped the indicators working. Several people, including the garage looked at it, but it took an electrical specialist down south who was a mate of a mate, to suss out that there was an issue with the rear window heater, and once he removed that from the circuit, the problem was solved. Prior to this, all kinds of other things were tried and checked; the wiring in the brake light circuit was fine, the brake light switch was fine, the indicator stalk was fine, the hazard lights were fine, etc etc. So the leccy wizz got it fixed and its been fine for exactly a year.
Tomorrow, its booked in for its MOT and guess what, yesterday, the brake light fuse blew, and the indicators died (the fuse is fine though). I stuck 2 new fuses in this morning and as soon as I brake, they pop.
The only thing I've done recently is tow both of our trailers (not at the same time
) and all electrics were fine both before, during and after. 2 days ago was the last time I towed, 1 day ago everything still worked, and then yesterday afternoon it all stopped working.
Admin please feel free to bin this if you think I'm out of order posting it here, but if its ok, can anyone suggest what to look at and how to check the circuit? I need to know if its worth me hoovering the muck out or not
Huge amounts of thanks in advance
