Frontera Technical Support • View topic - Strange disc on my propshaft
Strange disc on my propshaft by hipplew on Wed Sep 07, 2011 9:11 pm
Right this may sound daft but I have a strange disc on my propshaft :shock: now please remember that this is a monterey 3.1 with LSD 8)
looking at the rear of the transfer box there is a plate that links this disc to the propshaft the disc is about 8" dia by 1" thick it looks like some sort of composite stone :shock: the center is solid as that it is fixed to the propshaft by a plate either side the outer of the disc it held to the center disc by rubber bushes :?
yes I will get some pics up but it will be tomorrow
any ideas
Howard
hipplew
Re: Strange disc on my propshaft by Rifleman on Wed Sep 07, 2011 9:14 pm
Sounds like a doughnut joint. Hard to say without seeing it, but on some cars they are there instead of a normal type UJ joint.
They are supposed to stop vibrations.
Re: Strange disc on my propshaft by Rifleman on Wed Sep 07, 2011 9:19 pm
This is the kind of thing i'm talking about.
http://www.alibaba.com/product-gs/21789 ... shaft.html
Re: Strange disc on my propshaft by hipplew on Wed Sep 07, 2011 9:27 pm
Kieth, I will get some pics up in the morning but yes it does look some thing like that but circular so you mention that is for some sort of joint or to stop vibration but must have labottomised myself as I cannot think how it would reduce vibration because of the outer held by these bushes if anything I would have thought it would have created more vibration :? :? :? :?
defo. a confused dot com momment
Howard
hipplew
Re: Strange disc on my propshaft by Rifleman on Wed Sep 07, 2011 9:46 pm
A lot of the old Fords were fitted with them, especially the larger automatics. (Granada and Cortina MK3 onwards)
They do away with the traditional front UJ and fit these rubber doughnuts.
The rubber doesn't allow as much movement in the joint, as a UJ would, so the rubber acts as a damper.
I hope that explains a bit better, what i'm trying to say. :)
Re: Strange disc on my propshaft by jontera on Wed Sep 07, 2011 9:47 pm
my understanding of it is, that it reduces the harmonic vibrations caused when the prop is rotating. it does allow a little flex as half the bolt holes connect to one end (i.e the rear section) and the others to the other end..it's sort of a like a very basic universal joint, but with a more limited range of angles.
problems occur when one (or more) rubber section split sending the prop into an un-even rotation (can't remember the proper term, but it's like one of those spirograph pictures you used to try and make as a kid)..basically the weight and acceleration/braking forces cause it (the prop) to wobble off center
my old MK5 Cortina had one, when it went i got one off the shelf (after being sold compleatly the wrong one..long story, let's just say it was a Ford dealership that would argue your Ford didn't have certain parts that you wanted)..
(damn, my last bit was posted by Keith, just as i was typing)
edit* many thanks to Big Dav..centrifugal force was the term i was looking for..
Re: Strange disc on my propshaft by Drift on Wed Sep 07, 2011 10:28 pm
Is not the rubber doughnut Howard is talking about, look at the gearbox in this link :wink:
http://www.ebay.co.uk/itm/ISUZU-TROOPER ... 1c197c24ca
Re: Strange disc on my propshaft by Sir-Doris on Thu Sep 08, 2011 12:13 am
Some sort of gearbox flywheel perhaps?
With a bit of fiddling I bet you could use it as a handbrake with a set of old calipers or summat. Similar toy a landy rollover ;-)
Re: Strange disc on my propshaft by Ajsymes on Thu Sep 08, 2011 9:33 am
Transmission handbrake I reckon
Ajsymes
Re: Strange disc on my propshaft by Drift on Thu Sep 08, 2011 9:35 am
Nope, later trooper handbrakes are incorporated into the rear calipers :wink:
Re: Strange disc on my propshaft by adyclemo on Thu Sep 08, 2011 10:13 am
I was also going to suggest some sort of brake. May bo it could be turned into some sort of PTO. 8)
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: Strange disc on my propshaft by robbie on Thu Sep 08, 2011 10:36 am
Is the doughnut not there to help reduce judder when pulling away as the troopers run a solid flywheel with a sprung clutch ??
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: Strange disc on my propshaft by Drift on Thu Sep 08, 2011 11:00 am
Nope, the Trooper have a straight through prop :wink:
Re: Strange disc on my propshaft by Fatbaz on Thu Sep 08, 2011 1:06 pm
If the item in question is the same as that shown on the ebay link for the Trooper gear box, your looking at a harmonic balance weight. Their main purpose is to minimise/eliminate propshaft drone and vibration. We use them on a particular model of van that can suffer "prop harmonic acoustic issues".
The photo of the big rubber thing with the steel spacers is a "flexible coupling". It takes the place of a conventional UJ, the flanges either side of it are 3 legged affairs, each leg bolted to an individual hole and bush in the coupling. This arrangement was used at the prop flange of mark 1 Disco's (I've change quite a few and in some cases converted them to conventional UJ's). They also go some way to reducing drive line vibrations being transmitted from the axle back up to the transmission. Obviously they are maintenance free and will last near on as long as a UJ, especialy one that gets a regular dunking in the gloop we all love to play in.
Hopefully this cleared up the mistery.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: Strange disc on my propshaft by Drift on Thu Sep 08, 2011 1:31 pm
Ta Stuart :wink:
Re: Strange disc on my propshaft by Rifleman on Thu Sep 08, 2011 3:04 pm
Told ye :mrgreen:
Good info there bud.
Re: Strange disc on my propshaft by Sir-Doris on Fri Sep 09, 2011 7:27 pm
