Frontera Technical Support • View topic - A bit of shopping help
A bit of shopping help by PaulHooligan on Mon Sep 05, 2011 10:34 am
This may or may not be the correct area and my apologies if it is not.
I need wheel bearings for Dave 98swb ( 2.0 ltr ) I looked on Ebay and got myself confused could one of you very nice techy types please post a link to the ones I need??
ALSO having trawled through all the suspesnsion lift threads I got myself lost should I use Landy parts should is use Isuzu parts to a thick doorman such as myself these things are like speaking another language.
The question is what do I need? Could you put a list on this thread of the exact bits I need to order?
I know its a big ask but would really appreciate it.
Regards
Paul
PaulHooligan
Skype Username: paul-hutson
Re: A bit of shopping help by BoxCleva on Mon Sep 05, 2011 10:58 am
Front or rear wheel bearing matey ?
And the ISuzu springs from Milners don't lift the A's as far as I'm aware. You can use defender coils or spacers. I'm pretty sure Mark (MG Autos) is stopping supplying them , but he may have some stock left if you PM him
Re: A bit of shopping help by PaulHooligan on Mon Sep 05, 2011 1:14 pm
PaulHooligan
Re: A bit of shopping help by BoxCleva on Mon Sep 05, 2011 1:35 pm
No mate, it's very possible. People have used defender coils and classic RR coils to achieve the lift.
Here's a link that is deffo worth reading. viewtopic.php?f=5&t=36461&hilit=defender+coils
Re: A bit of shopping help by PaulHooligan on Mon Sep 05, 2011 2:11 pm
Read through all that and although it looks achievable still baffled.
What I really need is to be addressed as an amoeba and someone sit me down and say
"you need this from here and that from there" no choices no confusion!!! simples :D
PaulHooligan
Re: A bit of shopping help by BoxCleva on Mon Sep 05, 2011 2:25 pm
From reading that thread I would imagine it's these you are after > http://www.ebay.co.uk/itm/Land-Rover-De ... 1376wt_905 Although as I'm a B driver /owner it might be prudent to wait for another member to confirm before you hit the buy it now button :wink:
Re: A bit of shopping help by PaulHooligan on Mon Sep 05, 2011 3:17 pm
Next question what about the front ?
Would it not be easiser to replace all 4 shocks and coils with +2 all round??
PaulHooligan
Re: A bit of shopping help by fogman on Mon Sep 05, 2011 3:21 pm
i know l/rover coils have been used in the past to lift fronties but im not 100% sure which type have been used so the best bet is to contact mark [mg autos] because he supplies 2" spacers that fit above your existing coil springs, his fit either a or b so no confusion & being a member you know its quality gear, from memory theyre approx £60 a pair delivered :wink:
marks thread -
viewtopic.php?f=26&t=36435
Re: A bit of shopping help by fogman on Mon Sep 05, 2011 3:23 pm
theres no coils on the front paul, you have torsion bars which can be wound up higher so as to level go with the rears when spacers / longer coils are fitted :wink:
Re: A bit of shopping help by PaulHooligan on Mon Sep 05, 2011 3:30 pm
PaulHooligan
Re: A bit of shopping help by fogman on Mon Sep 05, 2011 3:35 pm
no coilsprings are fitted on the front end of a fronty, the front end has torsion bars each side, you can raise the front by turning a 27mm bolt [1 for each side ] which is positioned approx level with the rear of the front doors on the chassis rails, 4 full turns to approx 1" of lift :wink:
Re: A bit of shopping help by PaulHooligan on Mon Sep 05, 2011 3:43 pm
Ah simple then :D
PaulHooligan
