Let a squaddy loose across Soltau with one for a month, bet it won't even even last the first week, could you drag a dead chieftain bridge layer across the tank yard with one? No didnt think so...
Seen it done with a FFR Defender though. That said, it did end up sat in the workshops next to the tank a month later with a knacked clutch
