how capable
how capable by martynmcqueenie on Mon Aug 01, 2011 10:04 pm
how capable realy is an a series 2.5 tds with no mods
i take my truck over dunes and sand and water and never had any major probs but id like to know what extremes she really can handle
martynmcqueenie
Vehicle Name: The Betsy
Modifications: Wind deflectors fitted to all side side windows
Bosch spotlamps
Orange flashing light thingy lol
Refurbed wheels
Chromed towing electrics
12" sub and box with pioneer amp and upgraded component speakers front and back
Will update as i go trying to tidy up 1st
Re: how capable by Trugga on Mon Aug 01, 2011 10:11 pm
Whilst not extreme, here's a video I made of a beginners green lane trip, featuring three standard Fronteras:
You'll be surprised at what a standard Frontera can actually do.
Re: how capable by martynmcqueenie on Mon Aug 01, 2011 10:19 pm
cheers for that trugga but im looking to find out how extreme i can go before having to lift etc
martynmcqueenie
Bosch spotlamps
Refurbed wheels
Re: how capable by stu_iow on Tue Aug 02, 2011 12:00 am
good video there Trugga.
I read that before going into water, you have to put a bolt in on the gearbox or something? Did this (or anything else) need doing before you take these frontys into deep water?
stu_iow
Vehicle Name: Workhorse
Modifications: CB
Re: how capable by Sir-Doris on Tue Aug 02, 2011 12:29 am
Putting a bolt into the gearbox before wading??? Thats a new one on me. Only possible reason I could think of for doing that would be if a gearbox breather had been disconnected/lost and you needed to temporarily plug the hole.
The gearbox has a couple of small holes in the bell housing where it mates to the engine to allow water to drain. Water will get past the clutch release lever boot and into the bell housing after any lengthy wading excursion there is almost always some clutch judder for a couple of hundred yards.
The gearbox itself is sealed apart from the vent hole at the top by the quadrant box with a plastic splash cap and that is an easy fix. Remove the cap and run a length of fuel hose high up into the engine bay while making sure to avoid the exhaust on route.
As for how capable they are. In standard form with a half decent set of All Terrain tires on they will climb straight up a 45 degree slope (possibly more but I dont have an inclinometer) with little problems provided its a stable surface. Hardpacked gravel, tarmac and even sand with a bit of a run up.
Problems can arise though when cresting hills as the underside of the vehicle can beach itself leaving all 4 wheels off the ground if you are particularly unlucky. Less likely with a SWB.
Approach and departure angles are not the best either so when coming to a steep incline the front bumper can hit the incline before the wheels start to go up, same goes for the rear once the front end is climbing, towbars and rear bumpers can drag on the ground before the rear wheels hit the incline. In extreme circumstances (very steep hill) the rear wheels can be left hanging while the car is supported by the front wheels and the towbar/bumper. Again slightly less likely with a SWB.
Ground clearance at its highest point is only about 11" on a standard frontera so picking your line carefully can avoid most of the inevitable knocks, bumps and bangs to the undercarriage.
Cross axleing (one wheel in the air spinning and no drive to the other wheels) is fairly common due to the front suspension setup (Independent Front Suspension, IFS) but as above picking your line can avoid most occurrences.
The lowest point under the whole car is the center of the rear diff. Its a fairly heavy duty item and I cant count the number of times Iv dragged it across something and its shape lends it to slide over objects rather then binding on them.
Standard tires are rather small, typically 29" or so and upgrading to a 31" or 32" tires will add another 1" to 1.5" under the diff. Doesnt sound like a lot but you will notice the difference.
Wading/fording is pretty good. When my truck was mostly standard (basic 2" lift, no snorkel) I drove through the better part of 500 meters of fast moving flood water which averaged about 2' in depth (much better then the handbooks 11" or 12" maximum). Carpets were slightly damp as the doors arent waterproof, more splash proof.
Hope that helps and Im sure other will add their thoughts.
Re: how capable by drinksoptional on Tue Aug 02, 2011 12:33 am
join the scottish mud club and we will take you round drumclog and you can go extreme as you want
Re: how capable by martynmcqueenie on Tue Aug 02, 2011 8:32 pm
scottish mud club what costs are involved and how local to ayrshire are they
martynmcqueenie
Bosch spotlamps
Refurbed wheels
Re: how capable by drinksoptional on Tue Aug 02, 2011 11:41 pm
the forum is local just google it register.
drumclog is along A71 cost£25 few of us going out saturday welcome to come its a non club meet.
we have alot of members from the west coast
Re: how capable by jimmybhoy on Tue Aug 02, 2011 11:53 pm
If i still had that Captivia on hire, i would have taken that up for a giggle :lol:
jimmybhoy
Registration Year: 2004/04
Re: how capable by drinksoptional on Wed Aug 03, 2011 12:37 am
tam took his mondoe up one of the hills.
i would of liked see how it handled
Re: how capable by drinksoptional on Fri Aug 05, 2011 12:35 pm
you coming to drumclog tomorrow. dont worry you wont get left stuck
Re: how capable by Drift on Fri Aug 05, 2011 12:49 pm
The gearbox plug is for some Land Rover gearboxes :wink:
It is very very difficult to say how extreme you can push a standard car, you need to be ready to break stuff on the car to test this theory, plus there are so many terrain variables to take into account.
Best way is to just find something tame at a pay and play then get more adventurous :wink:
