Hi im struggling to get the bonnet lined up on my Astra.It a 2nd hand original GM bonnet but been at it for ages and cant get it lined up.Any tips?Thanks in advance cheers Adrian
Height at the front is adjusted with the black bungs on the slam panel by turning them. The squareness is by keeping the bolts loose on the hinges and jiggling it till its in position and nipping them up.
Remember when adjusting the gap between wing and bonnet. Do the bolts up tightish so you can still move it by hitting it with your hand but not loose enough that the bonnet would move when you lift it to tighten them fully.
Looks like I'm in trouble with the Mrs's again... She asked me what I'd most like to do to her body... Apparently "Identify it" is not the correct answer!
Modifications: Drive a 2.2dti olympus, 2.8 lwb and 2.0i sport. Breaking... 2.4i and 2.3td 2.0i C20ne and x20se x 4 2.8tdi x2 2.2i A 2.2i B LWB x3 x22dth B dti lwb x3 y22dth B dti lwb x5 Call Fronty4x4spares on 01622 739908. Same day dispatch, next day delivery on 95% of items.
