Unlucky mate, but to be honest 9 seconds for a snipe is just plain careless and could be beaten. Must admit, if I really want something then I'll snipe it and mostly get the hit in the last 2 maybe 3 seconds tops. It really is the way to grab a bargain, even more so if the seller hasnt put a reserve on.
