Frontera Technical Support • View topic - Does anyone know what.....
Does anyone know what..... by hobsey on Sat Jun 11, 2011 1:10 pm
this is?
I have started to dismantle my dash ready to change the heater matrix next weekend, as I was taking the steering column cover off the pictured item fell out.
For the life of me I cant see where it goes or what it does.
Its a 2 piece item i.e its a nut over a bolt and the hole in the top takes an allen key.
Any ideas?
hobsey
Vehicle Name: Fanny
Modifications: Air freshener
HD Trooper rear coils
2" coil spacers
265/75/16 Fedima Frontieras
Recovery shackle
Magnamount Aerial
Re: Does anyone know what..... by ARMYOF1 on Sat Jun 11, 2011 1:25 pm
Is it the clutch pedal or brake pedal adjusting bolt .
ARMYOF1
Model: 2.0i Sport Niagra 3dr
Re: Does anyone know what..... by hobsey on Sat Jun 11, 2011 1:50 pm
Might be.
Will have a look.
hobsey
Vehicle Name: Fanny
2" coil spacers
Recovery shackle
Magnamount Aerial
Re: Does anyone know what..... by hobsey on Sat Jun 11, 2011 2:38 pm
Not for them.
The hole for the clutch one is too big and the brake peddle on is still there.
hobsey
Vehicle Name: Fanny
2" coil spacers
Recovery shackle
Magnamount Aerial
Re: Does anyone know what..... by Big Dav on Sat Jun 11, 2011 10:24 pm
Nothing to do with the steering wheel adjustment handle is it?
Re: Does anyone know what..... by hobsey on Sat Jun 11, 2011 11:08 pm
hobsey
Vehicle Name: Fanny
2" coil spacers
Recovery shackle
Magnamount Aerial
Re: Does anyone know what..... by mickh on Sun Jun 12, 2011 7:29 pm
I think its a chukit bolt.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: Does anyone know what..... by drinksoptional on Sun Jun 12, 2011 8:15 pm
it must be something to do with steering then. Check the haynes manual and see if there is anything in there around same area
Re: Does anyone know what..... by andysd1 on Sun Jun 12, 2011 8:45 pm
that looks like one of the three bolts that hold the top half of the column to the bottom, just behind the wheel and about 6" down you should see a triangle with three bolts in it, check they are in place,
Re: Does anyone know what..... by AskDean on Mon Jun 13, 2011 8:44 am
try where you steering lock is there is 3 or 4 bots that bolt the steering collum to the bulk head that come loose over while and cause the steering wheel to drift a little on its mounting these bolts are normally snapp off domed ones but near them is one that looks like that in mine fom when i was tighen them up
AskDean
Skype Username: askdean
Re: Does anyone know what..... by rospicer on Mon Jun 13, 2011 6:04 pm
I think Andy is spot on there... It looks like one of those 3 bolts holding the top of the steering column. Its very common for them to loosen over time. Have a look from under the column upwards I think the stud goes in 1st using an alan key and then the nut tightens on. Sit in the drivers seat and shake the steering wheel, there will be a bit of play if one is missing
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: Does anyone know what..... by hobsey on Mon Jun 13, 2011 10:38 pm
I have no steering wheel play without it since I have tightened up the sheer bolts which always vibrate loose.
Had a look on the workshop manual, nothing there either.
But I will have a look underneath the column tomorrow.
Cheers guys.
Will let you know if I find where it goes if it doesnt end up in the bin first.
hobsey
Vehicle Name: Fanny
2" coil spacers
Recovery shackle
Magnamount Aerial
Re: Does anyone know what..... by hobsey on Thu Jun 23, 2011 7:13 pm
Forgot about this thread.
Cheers for everyones help, andy was right. Bottom bolt on the steering column.
hobsey
Vehicle Name: Fanny
2" coil spacers
Recovery shackle
Magnamount Aerial
